Parts Organization
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926
MTFCA Number: 29784
MTFCI Number: 22970
Parts Organization
Post by Mustang1964s » Fri Jul 31, 2020 8:35 pm
I have a new bigger garage that is filling fast. Shelves are being built.
The parts are being sorted, the issue is how to get them organized.
I need some ideas on how to keep the little stuff like head gaskets/ header gaskets/ specialty bolts ect...
How do you store engine parts and transmission and the small stuff.
Any and all help would be greatly appreciated.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Parts Organization
Post by CudaMan » Fri Jul 31, 2020 8:55 pm
I use Plano clear plastic tackle boxes for the small stuff. :)
https://www.grainger.com/product/30F072 ... 8006005229!
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Fri Jul 31, 2020 9:25 pm
I have a shed ( or two) for parts. I hang them on the wall with wire. Shackles, perches,brachets, horns, lights ect. No digging through boxes or shelves. Fuel tanks, radiators, rad shells all have someplace to twist a wire and hang them up. Small parts I am using organisers with all the little draws. Label the front of the draw.
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Post by A Whiteman » Sat Aug 15, 2020 5:46 am
Wooden boxes made from ply and odd bits of wood. I made them to 'standard sizes' so they fit in shelves in 'combinations'. All boxes are the same length, just various widths so you can fit 1, 2, 4 or other combinations in each 'bay.
Narrow boxes with more dividers worked well for different bolt and nut sizes or smaller parts.
Fairly easy to make if you have a table saw or even a skill saw cutting to 'standard' widths and lengths, then nailed together (I have the luxury of an air nailer).
All have contents 'vivid' marked on the ends for quick reference.
MTFCA Number: 1219
Post by Rich Eagle » Sat Aug 15, 2020 11:56 am
We throw away a lot of good parts containers. I like plastic oil bottles with tops cut off and Mixed Nut cans. I make labels for them.
For these shackles I just nailed some boards to the side of my shelf. The bench with drawers was made form scrap lumber from a dumpster.
Nails on rafters are great parts hooks. Best for lighter parts than loading them too much.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Aug 15, 2020 11:58 am
Banana Boxes. They are strong and durable.
Some of these are over 35 years old and still good as new.
And they are free at the grocery store.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Aug 15, 2020 1:09 pm
I put my small parts organizers an a lazy-susan turntable.
It gives me a very high density storage on a small footprint.
It is also harder to stack stuff in front of to block access.
Be_Zero_Be
