FJ - Replacing the wood floor in an enclosed trailer
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
Post by FreighTer Jim » Mon Aug 24, 2020 5:47 am
I usually buy a new custom built enclosed car hauler trailer every 2 of 3 years.
But COVID-19 has created a shortage of labor & materials resulting in a delay for new trailer construction.
So I decided to replace the wood floor in my 35 foot custom enclosed car hauler.
I could not do this without help and I am fortunate to have made some good friends over the years traveling.
So here we go ..... πŸ˜‰
First the wood on the side walls had to be removed.
My good friend Mark who is a skilled carpenter did
that because we wanted to use those pieces for patterns.
The existing floor is 3/4 inch plywood.
I have my trailers built with floor - sidewall - roof
cross members on 12 inch centers.
I started installing etrac about every 4 feet width wise
Several years ago surface mounted on the wood floor.
As I started pulling up the old floor - I had to remove
the 1/4 inch bolts - fender washers - lock washers
so I could re-use the etrac.
FJ
Google β€œ Model T Transport β€œ
MTFCA - MTFCI - MAFCA Member
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Mon Aug 24, 2020 8:35 am
So I took up six sheets of plywood but left the front six or so feet alone - it was in good shape.
Mark cleaned it with some degreaser πŸ‘
Mark cleaned up the fender well boxes.
We are painting them.
Just about ready for the new plywood πŸ˜‰
FJ
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: FJ - Replacing the wood floor in an enclosed trailer
Post by Burger in Spokane » Tue Aug 25, 2020 12:23 am
Are you saying the floors had "gone bad" ? How so ?
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Tue Aug 25, 2020 4:34 am
I requested the floor be screwed down to every cross member - it wasn’t - many screws had missed the mark.
Gas - oil - fluid stains had gathered over time.
FJ
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Tue Aug 25, 2020 4:39 am
We cleaned & repainted the cross members as we installed the new floor.
Then Mark put new sidewall wood up.
FJ
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Tue Aug 25, 2020 4:44 am
Several years ago I combined the four piece aluminum ramp set to make two long ramps.
I thought about storing those underneath by having brackets built - Jerry came out to take a look.
It was decided to break down the ramps to four pieces
and build some brackets to attach them to the sidewalls.
Jerry designed some and installed them on Monday.
FJ
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Wed Aug 26, 2020 8:11 am
With the new floor down - Mark applied a two parts epoxy floor coat system yesterday morning πŸ˜‰
FJ
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Wed Sep 02, 2020 2:17 am
FJ
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Wed Sep 02, 2020 4:26 pm
Pretty nice Jim! Now you will have to wipe up those oil drips. They wont soak in before you stop. :D
MTFCA Number: 1219
Post by Rich Eagle » Wed Sep 02, 2020 5:44 pm
REO Speedwagon?
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Wed Sep 02, 2020 9:06 pm
Small $4 Harbor Freight blankets go under every vehicle
1925 REO Speedwagon Dump Truck
FJ
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Thu Sep 03, 2020 12:33 am
Wonderful thread!
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Post by A Whiteman » Thu Sep 03, 2020 5:25 am
And it looks like "home away from home" in there too! Good idea,
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
I get by with a little help from my friends
Post by FreighTer Jim » Thu Sep 03, 2020 9:16 am
I couldn’t have done this without the help of Mark Atkins and Jerry Kramer of Richmond, Indiana πŸ‘
Just like I couldn’t or wouldn’t want to go down the road
every day without the help of Friends πŸ˜‰
I Transport To Tell Stories From The Road πŸ‘
When that gets boring or tiresome - I will find
something else fun to do 😊
FJ
tdump
First Name: Mack
Last Name: Cole
MTFCA Number: 28146
Post by tdump » Sat Oct 03, 2020 2:25 pm
When mounting the xtrack or Etrack to the floor,there probably some holes that are not lining up with a frame rail,so do you put a backing plate under the trailer floor to spread the burden of pull or how does it look under the trailer as to how the track is mounted? Just curious as I have the new brake kit and such for my trailer and Xtrak is my next money to spend
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Securing etrac
Post by FreighTer Jim » Tue Oct 06, 2020 4:21 pm
Hi Mack πŸ‘‹
Standard 1/4” x 1-1/2” bolts with large fender washers - lock washers - nuts holds the etrac securely to the 3/4” CDX plywood floor.
FJ
tdump
First Name: Mack
Last Name: Cole
MTFCA Number: 28146
Post by tdump » Wed Oct 07, 2020 4:31 pm
Thank you sir.
