How does this work?- Tapping machine
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Wed Sep 02, 2020 8:36 am
Last Name: Seth
Re: How does this work?- Tapping machine
Post by perry kete » Wed Sep 02, 2020 10:38 am
Any data plate information on it?
Name of manufacture, Date of manufacture, Machine numbers, etc.
Any additional pictures?
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Wed Sep 02, 2020 10:43 am
Here is the plate.
Thanks.
MTFCA Number: 1219
Post by Rich Eagle » Wed Sep 02, 2020 11:07 am
This tells a little bit.
Advertisement from the 1919-11-06 issue of "Canadian Machinery"
Looks like you kissed out on this one;
https://www.bidspotter.com/en-us/auctio ... 2d00051847
This shows the chuck clearly.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Wed Sep 02, 2020 2:45 pm
Here's a great instruction video on a tapping machine of the era !
https://m.youtube.com/watch?v=c6kmdkWXKc8
Leo van Stirum, Netherlands
MTFCA Number: 1219
Post by Rich Eagle » Wed Sep 02, 2020 5:47 pm
Thanks Leo. Nice threads.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Oct 06, 2020 10:06 pm
Much larger than a Tapmatic machine. But those have the same 2 drive clutches, one forward, and one aft, just like this big boy. The advertisement mentions tapping 5/8" diameters, so this is a heavy duty unit. A Tapmatic has the same arrangement of clutches, but they are in a small tubular head. If you apply ANY downforce on them, they tap forward. If you relax the down force on the spindle, or lift it a little, the reverse clutch kicks in and they rotate backwards. It is very easy to control them, and since the spindle keeps the tap in line, it reduced tap breakage by a huge amount. This must have come from a factory making heavy equipment, maybe steam engines, or steam locomotives, or large marine engines. It is too large for anything on a Model T or Model A. If you want to sell it, check out the old farm engine sales forums. Some of those big engine owners might be in need of such a machine.
Look up "Tapmatic" and you can see a modern version, but useable on 0-80 up to 5/16" diameter threading or so.
andywilson
First Name: Andy
Last Name: Wilson
Post by andywilson » Wed Oct 14, 2020 10:01 am
Tapping machine involves a process where two pieces of metal are fastened together. That also helps drill a hole where screws are utilized. The use of tapping machine helps complete several tasks while saving time and labor. The process is just like tap and die that assist in the manufacturing process to make metal.
