What car is this?
Topic author - Posts: 1915
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
What car is this?
Others have done this and now it's my turn. I know we have some real car experts out their so like the guys on car talk used to do, I'm going to see if I can "stump the chumps" (no offense...) I'm going to post a photo from a car I recently saw sitting in a storage building and see if anyone can identify it. If no one gets it on the first photo I'll add some additional photos with more clues. One hint - it is pre-WWI. Have fun!
What is it?
What is it?
- First Name: Henry
- Last Name: Petrino
- * REQUIRED* Type and Year of Model Ts owned: 1918 TT
Re: What car is this?
I tried to cheat and searched the Prest O Starter. I found this list of cars that were planning to use them:
- MTFCA Number: 1219
It has an American Bosch magneto switch too if that helps.
- First Name: Leo
- Last Name: van Stirum
I noticed the button on the left reads 'American Bosch' i have no clue
Leo van Stirum, Netherlands
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
You could buy the Prestolite starter kit, so could have been installed after market. Thomas Flyer?
1920 Dodge touring
1920 Dodge touring
- Last Name: Juhl
Henry, the car pictured is not on your list. My understanding is that the Prestolite starter was a factory installation. More hints, the car was manufactured in Michigan and had a unique transmission.
- First Name: Charles
- Last Name: Foyle
- * REQUIRED* Type and Year of Model Ts owned: My Corolla doesn't count.
It is a Metz, isn't it?
Charles F.
Charles F.
More likely a Cartercar.
- First Name: Henry
Dang guys. How hard can this be? I've already eliminated 62 possibilities.
Of course, I personally have no idea what it is.
- First Name: Rich
- Last Name: Bingham
- Last Name: Juhl
Ok.... One of you got it but I'm going to show another photo before giving it away
- Last Name: Juhl
No more guesses? Bragging rights go to Wayne....it's a 1912 Cartercar. It is currently gathering dust among some newer cars in a building near me. It belongs to a friend who has at least 50 various cars dating back to 1901 of which only one, a 1925 Model T Roadster, is ever driven. He has about 15 Model T's and barns full of stuff. He has no plans to do anything with any of the cars, being content just to own them which I find sad.... There's going to be a hellava auction some day.....
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
The Presto Lite Starter was an interesting invention. That handle on the dash when pulled out allowed acetylene to flow from the tank to the pump. The Ignition system was a battery operated buzz coil which was timed thru the magneto to fire individual spark plugs. Each cylinder had a copper line for the gas to flow from the pump to the cylinders,
So you pulled the handle filled the copper lines to each cylinder, then quickly you pressed the buzz coil button which energized the all spark plugs and the one where the magneto rotor was pointed fired and if all went well an explosion happened which rolled the engine over and with the acetylene charges in the rest of the cylinders and their respective spark plugs firing hopefully the engine would start. There are a number of cases where the gas over filled the cylinders and the cylinders were blown off the crankcases and the engine became junk. This was a very short lived dangerous starting apparatus and by 1913 was replaced with the electric starter motor. My brother has a 1912 Case touring with this system and he does not have the kahunas to even try to start it with the Presto Lite starter.
brasscarguy
brasscarguy
- First Name: Henry
Dang. It sounds more like a means to make a bomb than start an engine.
I haven't been very active with the things I enjoy for too long now. However, when I was, I went on quite a few tours, knew a lot of good people in the hobby, and met a lot of collectors. On a Horseless Carriage Club tour I went on about fifteen years ago, we drove for miles through the California redwoods, and went to a historic ranch in a small town few have ever heard of. The family had owned the ranch for many years, and also collected early automobiles. Among about a dozen automobiles, were two Cartercars.
When I first looked at this thread, I knew instantly that I had seen one of those Prest-o-starter handles somewhere before, and saw it up very close. But I couldn't pullout where I had seen it. When I looked in here the next day, the instant I read Charles F's Metz comment, it hit me! It was that Cartercar I had seen fifteen years ago. I got to look very closely at that car. He was doing some minor adjustments to the transmission getting it ready for a tour he was planning to go on about a month later. The front seat cushion was out and we talked about their unusual transmission quite a bit. I got to slide the lever and watch the mechanism do its thing. And we discussed the Prest-o-starter for several minutes! HIs was original to the car (actually a very nice mostly original car!), however he did not have it connected to the Prestolite tank. He said he wasn't sure he wanted to actually use the starter system.
A fun "What-is-it" Tim J! And for me, another fun trip down memory lane.
- Last Name: Juhl
Wayne and all, glad you enjoyed it. My friend has a couple more unusual vehicles so maybe I'll do this again sometime
The Cartercar certainly evolved over it's 10 year span. I have been around a couple of two cylinder ones but not the later ones. In 1976 when Jimmy Carter ran against Gerald Ford there was a mock race between a Cartercar and a Model T Ford in one of the publications. (I don't recall which) I believe the Vintage Ford also mentioned it.
Thanks for the quiz.
- Last Name: Juhl
I’ve been informed that this is the only surviving Model S that the Cartercar.org people are aware of. Hopefully someday it will be restored and back on the road.
