Pony Tank CO2 MIG Shielding Gas Regulator?
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Jul 14, 2021 9:29 am
I have a CO2 pony tank that I want to use for MIG. However, my usual gas regulator adaptor is too big, see picture. I have this other regulator that came with the tank but I am not sure how it works. It has an attachment with a power cord on it. No markings or manufacturing number on it. Can I use it? If not what regulator or adaptor should I get to use this? The input to the Chicago Electric MIG is simply a tube with a zip tie to keep it snug.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Re: Pony Tank CO2 MIG Shielding Gas Regulator?
Post by Craig Leach » Wed Jul 14, 2021 10:10 pm
Hi Ignacio,
Most welding shops sell the CO2 adapter. My thought is does the welder have a gas solenoid biult in? Some Migs come set up for flux core wire only. If not then the solenoid will be needed to turn the CO2 on & off as you weld. If it has a solenoid biult in then you should be able to just remove it. Shielding gas is not cheap so make sure no matter how the hose is conected it does'nt leak. looks like you are on the way to being a welder. Good luck.
Craig.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Thu Jul 15, 2021 10:26 am
Truth be told I found a CO2 tank on the curb and did a swap with Praxair for the current certified filled one. The regulator came with it and might/probably is a kegger type. Is that 'ok' to use? I would think a regulator is a regulator.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Thu Jul 15, 2021 12:56 pm
The electric cord gizmo on the CO2 regulator is a mystery to me though. What might it be for?
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Jul 16, 2021 6:20 pm
You find cool stuff on the street! Me it's refrigerators, stoves and maybe lumber. :) Oh wait, I did find a big screen flat TV. Mom does not like them, people are too life sized! LOL
1920 Dodge touring
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Sun Jul 18, 2021 1:58 am
Yes I figured out the corded item was probably a pressure switch so I took it off. I removed a stuck gauge needle and replaced it in the zero spot will it work? Answer is yes. Found the last fitting needed in the to return to shelf box of odds and ends. MIG worked pretty well once I was able to get this on. Not bad for only a few dollars. I love curb finds when they work out.
