sstrang little 4 cyl. engine
Jim Sims
First Name: Jim
Last Name: Sims
MTFCI Number: 13377
Post by Jim Sims » Sun Dec 01, 2019 11:38 am
Hoping someone can identify this little engine .Might be a boat engine.
PDGx
First Name: Paul
Last Name: Grohsmeyer
MTFCA Number: 27359
Re: sstrang little 4 cyl. engine
Post by PDGx » Sun Dec 01, 2019 12:39 pm
Not enough visible markings to tell the make, but could be from any number of industrial uses.
I have a similar 4cyl from an industrial sweeper. The keyway on the output would indicate a pump of some sort (hystat or water) could have been attached. The pulley offset is also similar as the fan probably had to be located out of the way to fit the application.
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Mon Dec 02, 2019 10:14 pm
The water cooled exhaust manifold indicates that it' s boat motor. Possibly a sailboat motor?
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Mon Dec 02, 2019 10:28 pm
Sailboat motor ? Isn't that cheating, or a contradiction in terms ??? :lol:
bud delong
First Name: Kenneth
Last Name: DeLong
Post by bud delong » Tue Dec 03, 2019 4:53 pm
Gray Marine?? :D Bud.
yukonjack
First Name: Jack
Last Name: Murray
MTFCI Number: 24449
Post by yukonjack » Tue Dec 03, 2019 7:32 pm
Universal Motor made a good many marine engines and engine powered light plants in the hundred years between the 1890s and 1990s; maybe one of theirs? I know they were still building a 30 hp flathead 4 they called the Atomic Four in 1980, because I bought a brand new one then to repower a boat I had. This one is not an Atomic, but I've read they sold tens of thousands of a previous version, the Utility Four, for use in lifeboats during WWII; I've never actually seen a Utility Four so can't say for sure, but there were a bunch of them out there in the '40s and '50s.
http://www.oldmarineengine.com/discus/m ... 62687.html
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Dec 03, 2019 7:45 pm
I would look at photos of Waukesha and Hercules .It is a industrail engine.Probably on a pavement roller or sweeper or something along that line. I have a small single cylinder Hatz desiel from a pavement roller.Similar hook up.
Post by Mark Gregush » Wed Dec 04, 2019 12:29 pm
I was going to suggest Smokstak unknown engine section, but darn if I could find it. Still might be worth the look.
https://www.smokstak.com/
I know the voices aren't real but damn they have some good ideas! :roll:
1921 Huckster
