My T hauler is finished.Almost.
Topic author - Posts: 1275
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
Is any shop project ever really "done"? Nope.Still got to install more floor tie downs and a winch and mount for it.
BUT so you folks won't think I have curled up in a Lazy Boy and become a key board Curmudgen, here is what I have been working on for hauling the T pickup.
I built this from scratch. I had the basic frame put together,no ramp or anything about 5 years ago.But found a defect in the axle I used and had other projects and issues so it got put on the back burner. 3 years ago a freind remodeled his house and pulled all the decking down that was only about 6 years old and gave me alot of the wood. SO I had a floor.I found a good used axle this spring and it motivated me to get back on the project.I got the 91 pickup fixed up ,that took October,then I put this in the shop and decided it was not coming out until it was ready to use.
Some material like the 2 inch tube for the outside frame and the angle iron for the ramp and the expanded metal for the ramp were bought new. The angle iron railing and crossmembers and other stuff was used. Floor coating is some exspensive water proofing from Ace hardware that got reduced to 5 bucks a gallon. The springs for the ramp lift assist are from Lowes. It is actually a bit on the tight side,you about have to chase it shut once it gets past a certain point. The latch arms,are spring loaded to stay up to save me bending over to pick them up plus they act as guides when loading the T.
About 450 cash outlay,countless hours of work. A equal trailer with the lift springs,tool boxes,jack and such would be around 2400 bucks.
Now that it and the T are finished,I can get started with the titleing work.I can haul it now to get apprasials and such.
- First Name: Mack
- Last Name: Cole
Re: My T hauler is finished.Almost.
A couple more pics.This will give you some idea as to why I was asking last year about tieing down stuff on a trailer.
This and my tandem trailer will both need some more stuff on them to tie to.
Now that this trailer is finished you can see more about what might be a better idea for tieing it down.I was going to put the Xtrak stuff on it,but for the moment,the money is not loose for that.So I put some tie downs on it I had laying around.All US made and bolted to the frame and not just the wood. The trailer is 71 inches wide by 14 feet long.
- First Name: Dennis
- Last Name: Seth
Mack,
That is a very nice looking trailer and a great looking T! The pick-up you're pulling it with ain't shabby either! Now since you've finished yours you'll have time to build one for me!
Wow! The T and the hauler both look great! You do nice work my friend!
Thank you for sharing the pictures here, although I do think they should be on the General (all model T!) Discussion.
- Last Name: Stroud
- Board Member Since: 2011
Mack, as always, you do great work. That is a slick setup, both T and trailer. Dave
1925 mostly original coupe.
- First Name: Mack
- Last Name: Cole
I think I am in the wrong bussiness. I need to hire some folks to build trailers.
I got the title numbers for it a week or so after i finished it,Finally took it this morning to Dmv for inspection and all went well.The inspector said it had more lighting than required and complimented on the appearance. I also ask about hauling the T on it and he said NO problem.
BUT I went to the tag office. No problems with getting a title or getting a tag. The glitch is in the property tax value.And OF course a call to the county was met with ,"I will send you a appeal form and you will need to send photos".
They will also get a couple ad's indicating I can get this size trailer for around 2200 bucks new.
Take a guess,a wild guess as to what you would think a county would value a utility trailer for.
guess again!
$12,780 dollars. Yep,over 12 grand! I have maby 450 in it materials wise.
guess again!
Mack, I have one comment. It is not a criticism, as you have built a lovely trailer...it is a safety warning which I hope you take to heart: Your extension springs need a containment device for safety...(!!!!!). If ever the springs let loose, at best they will cause damage and at worst, serious injury could result. Consider something like this: https://www.amazon.com/Garage-Door-Part ... B00BWUIUZE
Stay safe, my friend.
NH Full Flow Float Valves
- First Name: Mack
- Last Name: Cole
I am in the planning stages of a pvc pipe collaspable tube for them.
Twelve grand??? They must be nuts! (Or crooked!) In Califunny one can buy a similar single axle utility trailer brand NEW for just over a thousand dollars! When I bought my heavier duty two axle sixteen foot trailer about 20 years ago, it was only slightly over two grand NEW. I know they have gone up in price over the past twenty years, but I still see them advertised for about 3500.
- First Name: Mack
- Last Name: Cole
If you live here,the word crooked comes to mind but in reality,I think Crazy is more like the truth.A computer spits it out and the humans do nothing unless you fight it.
I could not belive they are making me go thru the entire appeals process.The state's hwy use tax was based on a 300 dollar value.
Why on the earth the computer would belch out 12,780 is beyond me.
I would bet that the clerk typed in "car hauler" and the system logged it in as an enclosed trailer. Too bad they didn't code "utility".
- First Name: Mack
- Last Name: Cole
You know i just checked and it is marked utility!! I am like? Wow,
BUT , With it's temporary tag proudly displayed it made it's first haul yesterday morning taking the little T to the Dmv for it's first siteing by state officials. So far not sure what will be done as far what it will be registered as , but he said no problem to get it legal to operate on the hwy shortly.
- First Name: Mack
- Last Name: Cole
Well I sent the county 4 pictures,and 2 printed ad's for equal trailers with their prices.
I put 1000 dollars as fair value,being a new 1 could be bought from 1200 to 2200 dollars depending on features.
They called today and said it would be lowered for tax value to a 1000 dollars.The guy said he was concerned the computer spit out such a number. Um, anyhow, just thought I would update.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Computers do not lie! Someone should write a song about that!
- Last Name: Dufault
- MTFCA Number: 303
Mack,
Good for you for appealing that nasty mistake!
And kudos for a nice job.
Dave
Dave
- First Name: Mack
- Last Name: Cole
Well a update,
Here is my refurbished Tandem trailer.I bought this trailer back in about 2006 or 7. Paid to much for it.The floor rotted out of it about 2013 or 4 and last I used it the tractor front wheel fell thru the floor.It had hydrolic brakes on it,the master cylinder was full of rust and such,tires had dry rotted, it was useless.It sat till 2018 and I started slowly working on it as budget allowed.Removed old flooring and ALL old decking screws so i could reuse the holes. I had the "catwalk" laying around and so i put it in the tire tread areas and let it sit until october and put it in the shop and decided it would be DONE before it was out again.The crossmembers were 24 on center,I added more ,although a size smaller angle,so now they are 12 inch on center.It has new electric brakes on it.repacked the wheel bearings, new radials. New 5/4 treated decking floor,new 5000 pound winch with wired and wireless remote,60 feet of e trak, spare tire and mount,and I modified ramps with expanded metal so the little T wheels and garden tractor wheels won't sink down between the angle iron runners. I removed the old jack that some nut besides me had welded to the side of the tongue and I put a 5000 pound rated tongue jack on it. The winch is pluged into a 2 inch receiver hitch and the winch and mount are desiged to be removed so it can be used on a truck or tractor.It also got a fresh coat of paint.
I know not to pull a T from the front axle like I tested the winch in the photo but it was slightly down hill and there was no binding .it just rolled right up.
I plan to add back up lights so that a back up camera can be wired in as well.
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
That is a sure way to bend your axle. Create a Y strap and pull from the frame or outer ends of the axle.
Ken Buhler
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
