Model A Generator
ABoer
First Name: Anthonie
Last Name: Boer
MTFCA Number: 19790
Model A Generator
Post by ABoer » Sun Dec 29, 2019 7:44 am
To day , I open a Model A generator from one of the club members.
All together it looks not to bad,but the collector had something strange .
It looks like that someone did this by hand .
Do one off you has ever seen this, and what could be the reason for this .
Thanks for your answer .
Toon .
thom
First Name: Tommy
Last Name: Coffey
Re: Model A Generator
Post by thom » Sun Dec 29, 2019 8:31 am
It looks to me like someone was cleaning in up on a lathe and got a little careless. :shock:
Post by Scott_Conger » Sun Dec 29, 2019 10:53 am
brush wore completely out and tension spring was bouncing and arcing on the commutator
Post by Mark Gregush » Tue Dec 31, 2019 1:28 am
The A generator does not have a tension spring like the T, they are a wound type spring mounted on the pivot post. The piece that holds the brushes has limiters to prevent the brush mount screw from coming in contact with the commutator if the brushes wore out or came loose, but if the screw worked out and the bracket got bent, that would do it.
If it passes the growler test it should be ok. Depending on how thick the copper is in the segments, take a clean up cut and clean out the grooves between the segments.
I know the voices aren't real but damn they have some good ideas! :roll:
1921 Huckster
