What is it?
- MTFCA Number: 1219
Re: What is it?
One of these.
https://www.bing.com/aclick?ld=e3pKGFmX ... dlt=strict
Car AN8 90 Degree Gas Oil Fuel Hose Line End Fitting Adapter Hose Connector
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Re: What is it?
They were only used on the two pedal cars.
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
Re: What is it?
Look like what I've used on airplanes for fuel lines, oil lines and brake lines in areas where rigid lines are not acceptable.
- Last Name: Hanlon
- MTFCA Number: 50191
Re: What is it?
I’m pretty sure they are high pressure oil pump lines from the HPOP to the cylinder head/fuel injectors on a Ford 7.3 Powerstroke diesel.
