First New Vane Actuators Fresh off the Assembly Line
Posted: Fri Jul 02, 2021 2:19 pm
Just inspected the first samples of the Vane Actuators from a new run. The workmanship, quality and machining tolerances are all excellent with window edge to window edge machining tolerances well within the specified +/- 1 degree tolerance. This is very important because it determines the cylinder to cylinder ignition timing accuracy and consistency.
Mechanical tolerances were verified by electrical performance test using the E-Timer and its specially designed test set. Cylinder to cylinder timing error is less than +/- 0.4 degrees. Note that Automatic Timing Advance remains active and accurate from 400 RPM to 3500 RPM during this timing accuracy test operating on 12VDC battery.
Please pass this information along to other interested parties. I am prohibited from posting this accomplishment on the discussion forum being the vendor who designed, developed and markets this item.
