Spring for Hand Brake?
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Nov 21, 2020 10:43 pm
In the Nov/Dec issue of Model T Times Dan Treace mentions an accessory ratchet pawl spring. Is this available or do you need to make one? Is it made from a commercially available spring? Thanks all.
Last Name: Gregush
Re: Spring for Hand Brake?
Post by Mark Gregush » Sat Nov 21, 2020 10:47 pm
The suppliers should all have them in stock. https://www.modeltford.com/item/3463R.aspx
1921 Huckster
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Sat Nov 21, 2020 11:41 pm
I have one on my speedster. Works great.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Nov 22, 2020 12:30 am
I used a spring from the local hardware store. No shipping.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Nov 22, 2020 12:26 pm
A suggestion on using the accessory spring - as it is quite strong, I recommend squeezing the release handle whilst pulling on the brake handle to alleviate premature wear on the pawl & ratchet !
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Nov 26, 2020 10:26 am
Amen to your suggestion Steve!. I totally wore out the tooth not squeezing the handbrake lever when pulled back. Learn by ruin 😀
