My 1926 Fordor is now listed on eBay
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Wed Oct 13, 2021 10:12 pm
A week or so ago I asked your advice on listing my 1926 Fordor on eBay. I received alot of advice and sincerely appreciate all of your help and, utilizing all the advice I received, I listed it on eBay tonight at 10:00 pm EST along with 24 photos. Thanks everyone for all your help. Jim Patrick
Re: My 1926 Fordor is now listed on eBay
Post by Wayne Sheldon » Thu Oct 14, 2021 2:52 am
Very nicely done listing!
For those that may want a shortcut?
https://www.ebay.com/itm/115045076107?h ... SwEahhZy4p
Good luck!
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Oct 14, 2021 11:29 am
Jim, Any way to put some spaces in the vehicle description and make the huge block of words into 3-4 paragraphs?
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Thu Oct 14, 2021 7:40 pm
Yes, Mike. Good suggestion. I’ll look into it. I’m sure there is a way. May make it easier to read. Thank you. Jim Patrick
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Thu Oct 14, 2021 7:52 pm
Hi Mike. I tried twice to break my description up into 3 paragraphs but each time I posted the changes, eBay did not recognize the changes and, both times posted it as one big description with no paragraph spaces as before. It was a great suggestion, but unfortunately I could not implement the changes. Take care. Jim Patrick
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Oct 14, 2021 8:07 pm
Yes, Ebay can be tough to navigate trying to learn the ins and outs without any help from them at all. Good luck with the sale! 😊
Luke
First Name: Luke
Last Name: P
Post by Luke » Thu Oct 14, 2021 11:32 pm
Jim,
I'm sorry to read that you may not be the first person to hear your T running in a very long time. It seems to me a pity also that you couldn't get the motor at least turning over 'cos I'm sure that would assist in the sale (and who knows you could even hear it going!).
If I lived anywhere near I'd offer to give you a hand but I don't, however I recently ran across a T with a similar issue (locked solid) which simply turned out the be the bendix - as you suspect in yours. To get it turning and running for the time it took to get replacement parts from the U.S. I just removed the gear completely from the starter and put it back in place to fill the hole, then it crank started fine...
It's a fairly straightforward job of a few minutes via the floorboards in the cab, I wonder if it's worth you trying that?
Luke.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Fri Oct 15, 2021 12:16 am
Thanks Luke. As much as I’d love to get her going and hearing it run, after 17 years, I think I am ready to pass the baton and let someone else do what I had been wanting to for so long, but my knees are bad and I don’t have the desire or time for it that I once did. Jim Patrick
