TT gear oil?
SamJenkins
First Name: Sam
Last Name: Jenkins
* REQUIRED* Type and Year of Model Ts owned: 1924 TT; 1925 Tudor; 1926 Touring
TT gear oil?
Post by SamJenkins » Wed May 29, 2019 9:55 pm
What weight gear oil for my TT rear axle? Also how much oil?
Chris Hansen
First Name: Chris
Last Name: Hansen
* REQUIRED* Type and Year of Model Ts owned: 1923 TT, 1927 Tudor
Re: TT gear oil?
Post by Chris Hansen » Thu May 30, 2019 2:48 pm
I use 140w in my TT and have since 1965. I don't drive it here in Michigan in the winter. I think the oil would be too thick. As to level, recommended up to the filler plug. I keep mine just below that level. Have fun.
Chris Hansen
Re: TT gear oil?
Post by Mark Gregush » Thu May 30, 2019 3:25 pm
If it has been sitting for a while, don't forget to add some at the upper plug at the worm drive. Unless it is early and does not have the plug, in that case I would jack one side up and let it run for a while then recheck the level. don't forget to chock the wheels so it does not drive off. :lol:
SamJenkins
First Name: Sam
Last Name: Jenkins
Re: TT gear oil?
Post by SamJenkins » Fri May 31, 2019 9:59 am
Thanks for the replies. I have always used 600wt filled to the pipe plug fill point on all my A's and T's. Reading in Murray Fahnestocks book on the Model T it talks about using 1 to 1.25 lbs of heavy grease or one pint of steam cylinder or 600wt oil in model T rear axle. This just got me to wondering what others were using in there axle. This is my first TT- it has been sitting for at least 15 years and I was wondering about the upper plug in the rear axle.
1924 TT Closed Cab
1925 T Tudor Sedan
1926 T Touring Car
