Spark Plugs for the Driver T
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Mon May 13, 2024 4:46 pm
What's everybody's personal experience with Autolite 3095 spark plugs for a "Driver" T ? What's your experience if you've ever used Older Firestone E-40-F plugs in your T ? Also Champion A25's ? (not the take apart type).
MTFCA Number: 51486
Re: Spark Plugs for the Driver T
Post by TXGOAT2 » Mon May 13, 2024 6:10 pm
I'm using Champion A-25s and get good results. Engine is near stock and has good oil control. Ignition is stock except for a New Day Timer.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Mon May 13, 2024 6:46 pm
Motorcraft Model T spark plugs are a good aftermarket plug. They work fine.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
MTFCA Number: 49752
Post by KBurket » Mon May 13, 2024 11:04 pm
I use Autolite 3095 plugs.
I drive between six and ten miles once a week exercising low gear up a long hill on one of my regular routes.
I’ve had plugs go bad on me so I change them once a year and clean them pretty regularly.
My motor is currently using a distributor.
I like that I can find them in a few of the auto parts in my area.
DaveBarker
Last Name: Barker
MTFCA Number: 30942
Post by DaveBarker » Tue May 14, 2024 8:49 am
I've been using the Champion A25 (aka 525) plugs with good results and no problems. Rajo head, Stromberg RF carb, bored 0.030".
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue May 14, 2024 9:53 am
I've used 3095 because they are the least expensive new plugs for a Model T. The local O'Reilly's can have them for me the next day. I don't expect them to last decades like some plugs. That may happen, but I've had a few fail in a year or two.Their advantage over original plugs is that they don't come apart in use like Champion X, Splitdorf, and other old timers. I do use original-type plugs, but I always carry spares. It's not a bad idea to do the same with modern plugs.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Wed May 15, 2024 7:21 pm
I just found a set of 3095 plugs I bought at Chickasha a few years ago. When I read this post I thought I had some somewhere. The older guy I got them from had them on his table and he couldn’t sell them. Brand new in the boxes for a dollar each. He told me they weren’t original and I was the first that asked about them. He came down on the price .50 each and they were mine for a dollar each! I guess times have changed!
signsup
Last Name: Brough
* REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
MTFCA Number: 31990
MTFCI Number: 31990
Post by signsup » Thu May 16, 2024 10:55 am
I know nothing about these air gap plugs other than a stash of them came in a Model T parts lot, so I presume the PO was running them. I have not installed them in my T but may do so to test them. NOS Champion
6 com 62. What little verbage I can find them is they are commercial plugs designed for engines that run hot, a cooler running plug.
I've got a little roughness in my T engine right now and connecting everything up after gas tank cleaning and lining. If it still runs a little rough, I'll replace the plugs with something and see if that helps. Then I'll move to the coils.
Anyone heard of these AC plugs?
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
Post by TRDxB2 » Thu May 16, 2024 12:30 pm
From the internet for AC 6-COM-62 plugs
6COM-62, 18mm plugs were listed as for "Ford and pre 1926 Harley." by spark plug dealer Donald McKinsey in 1994
from a discussion on aaca.org
My pre-war Champion catalog shows this 18mm plug as mainly intended for commercial vehicles and motorcycles. It's a "severe service" plug and is recommended for engines that run hot. (It's a colder type plug.) There were no specific vehicle recommendations in the catalog but there is a note that it can be used in some Studebakers, but it is indicated as a plug that can be used to help correct rapid gap growth, pre-ignition, ping, overheating and core fracture caused by hot running motors, high speed usage, heavy loads and long highway upgrades in hot climates.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Thu May 16, 2024 12:31 pm
If that's a gasket on there - it won't fit a T - they're 1/2 pipe !
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Thu May 16, 2024 12:34 pm
18MM is not the same as 1/2" pipe thread.
signsup
Last Name: Brough
MTFCA Number: 31990
MTFCI Number: 31990
Post by signsup » Thu May 16, 2024 1:17 pm
Would a early Ford and Harley plug really be 18mm? I haven't tried to thread one in yet, but certainly don't want to mess up a head.
A bunch of old cars
Sometimes they run.
Post by TRDxB2 » Thu May 16, 2024 3:13 pm
Good question. All depends on what one means by "Early"
Spark Plug (18mm Champion);
1933-37 Ford V8
1929-1952 Harley-Davidson WL
1936-1940 Harley-Davidson EL
1937-1947 Harley-Davidson UL
1941-1947 Harley-Davidson FL
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu May 16, 2024 4:31 pm
I believe Model T spark plugs were always half inch pipe thread, from the beginning. I don't know about all the pre-T models. The Model T parts dealers have adapters that let you use other sizes.
