Drive Train Assembly Order
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by mortier » Mon Aug 25, 2025 10:54 am
I have the engine, rear axle, and rear spring out of my T and ready for installation. Any idea for the best order of assembly? Photo shows rear spring going in, but I'm wondering if I should install the axle first.
Last Name: Hatch
Re: Drive Train Assembly Order
Post by Dan Hatch » Mon Aug 25, 2025 11:10 am
Think the Service Manual has that information.
jsaylor
Last Name: Saylor
Post by jsaylor » Mon Aug 25, 2025 12:46 pm
I always put the spring in first, being sure to center the square head center bolt into the frame. Then you can use the weight of the car and a small block of wood under the ends to help spread the shackles into the backing plates.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Mon Aug 25, 2025 3:48 pm
I agree with John on the rear spring going on first. It doesn’t make a lot of difference if you put the engine or rear end in first. I’ve always found it easier to stick the u-joint into the motor than to stick the motor to the u-joint.
Andy
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Aug 25, 2025 4:42 pm
Engine, rear spring, connect rear axle to transmission, then shackle axle to spring (using car weight & 2x4 blocks to spread spring).
