Steering shaft?
Posted: Mon Jan 27, 2020 7:36 pm
by D.Yoder
What is the correct angle for the bottom of the sterling shaft?
Re: Steering shaft?
Posted: Mon Jan 27, 2020 7:47 pm
by Adam
Try a rear hub on it. Maybe the same taper. Rear hub / axle shaft is 1+1/2” to 1’.
Re: Steering shaft?
Posted: Mon Jan 27, 2020 8:35 pm
by got10carz
Alot of tapers are 3 and1/2 degrees on each side. 7 total, although I've never checked a steering shaft. It would need to be in a lathe and indicated in.
