Headlight plain glass lens thickness?
Posted: Wed Jan 29, 2020 9:59 pm
by schwabd1
I need to have a couple plain glass headlight lenses cut. What is the correct thickness?
Re: Headlight plain glass lens thickness?
Posted: Wed Jan 29, 2020 11:08 pm
I believe I got the next size thicker than regular window glass. I don't know exactly how thick that is, but it's been fine.
Posted: Wed Jan 29, 2020 11:14 pm
by Mark Osterman
Need a glass circle cutter?
by schwabd1
"I believe I got the next size thicker than regular window glass."
I've got some of that around the shop.....I figured it needed to be thicker than that. THANKS!
Posted: Wed Jan 29, 2020 11:26 pm
by schwabd1
I don't have a circle cutter, I figure if double strength is thick enough I should be able to "freehand" that OK.
Posted: Thu Jan 30, 2020 11:37 am
I needed a lens cut for a speedometer. Hardware store butchered a piece of window glass (were going to charge $5). Went to a local stained glass hobby/window maker - used "lens glass" its thicker- made a perfect circle and ground the edges smooth for $5. I have the knowledge, experience, tools and time to do it (circle cutter, glass grinder, was a hobby, retired) but for $5 that included the material - why would I. Check it out you may have a glass shop nearby.
Posted: Thu Jan 30, 2020 12:16 pm
Those clear lens are 'round' and are about 1/8" thick. The round fit best with the 'clip' style retainers in the headlamp rim. Those are early style steel rims.
If using the H lens style rims, those are made with little tabs that rest against a squared off edge on the glass. That is a feature of the fluted Ford H lens. So your clear lens needs to be shaped with 4 flat areas to fit into those style rims.
Clip style rim for round lens
H Lens rim
