1926 Dash board screws
Posted: Thu Feb 06, 2020 10:19 pm
by Mopar_man
Is the dash on a 26 Touring held on with flat head bolts and washers that the head of the bolt fits into? Same to hold the steering column?
Re: 1926 Dash board screws
Posted: Thu Feb 06, 2020 10:54 pm
by Howard Tomlinson
Nickel plated oval head machine screws. Lang's sells them under "interior screw set". I can't find them locally.
Posted: Fri Feb 07, 2020 12:14 am
by jiminbartow
We have an old style hardware store here in central Florida called Crowder Brothers that has them. Some Ace Hardware stores have them too, in separate steel boxes in the fastener aisle. Jim Patrick
Posted: Fri Feb 07, 2020 12:39 am
by George N Lake Ozark
And held in place by square nuts on the backside
Posted: Fri Feb 07, 2020 4:41 am
On our Canadian products I believe there are no cup washers. The panel itself has a raised lip around the holes, and the screws sit in this lip.And, they are Robertson screws wuth the square hole drive.
Allan from down under
Posted: Fri Feb 07, 2020 9:23 am
by Gonenorth
You can get the screws at McMaster-Carr, Seems to me they are 1/4-20 oval head. Forget the length at the moment. Not real expensive.
Posted: Fri Feb 07, 2020 10:32 am
I personally like stainless steel.
