Mystery Front Axle Bits
Posted: Sat Feb 08, 2020 11:21 am
by RustyFords
I’m working hard to save every last little usable bits off of my ‘25 parts chassis before I haul the rest to the metal recycler and came across these little clamps.
I thought at first that they might be towing hooks, but they’re facing the wrong way. Could they be part of an aftermarket gizmo of some sort? If so, and someone is needing them, I’d like to find a new home for them.
They look too purposeful and fit too precisely to make me think they’re homemade.
Re: Mystery Front Axle Bits
Posted: Sat Feb 08, 2020 11:43 am
by Rich Eagle
I think they are for a strap type of shock absorber.
Posted: Sat Feb 08, 2020 12:08 pm
by Dan McEachern
Rich is correct- those clamps are for the webbed strap from a snubber to attach to the front axle. I believe Ford offered a snubber as an accessory on the improved Fords of 26-27. A common brand name was Gabriel. The snubber unit attached to the side rail of the frame near the front cross member and the strap from the snubber unit extended vertically down to the clamp on the front axle.
Posted: Sat Feb 08, 2020 12:15 pm
by dobro1956
They are correct. They are snubber strap brackets. Someone needs them. That is the part that is usually missing.
Posted: Sat Feb 08, 2020 12:50 pm
by Rich Eagle
Posted: Sat Feb 08, 2020 7:02 pm
by JSteele
Hi Don, sent you an email. I would love to purchase those. I have NOS shocks but not the axle mounting hardware.
Posted: Sat Feb 08, 2020 10:45 pm
by RustyFords
Hi John
Haven’t seen your email yet. If you text...text me at two81-seven87-8418.
No need to purchase them...I’ll just send them to you.
Posted: Sun Feb 09, 2020 2:34 am
by Altair
My grandson has those snubber straps on his Ford Ranger to control the suspension in rough terrain, they are aftermarket but still used today.
Posted: Mon Feb 10, 2020 5:07 am
by ABoer
Don A.
I have one [Snubbers] ,but I think there some parts missing .
Toon
Posted: Sat Feb 15, 2020 8:48 pm
by RustyFords
John...I removed the “gizmos” and started cleaning them up.
One of them looks almost new after some time with the wire wheel. The other one fought me more coming off and I broke the bolt. So you’ll have to find another square headed shoulder bolt to match.
I’m gonna try to extract the broken bolt and finish cleaning up the second one.
