Engine Miss
wayne thompson
First Name: wayne
Last Name: thompson
* REQUIRED* Type and Year of Model Ts owned: 1925 fordoor
Engine Miss
Post by wayne thompson » Sat Feb 08, 2020 12:03 pm
My 1925 Fordoor has an engine miss. So far I have installed new carb, installed new buzz coils, installed new timer, checked compression, checked for air leaks at intake, changed spark plugs but still have a miss. Compression is 48-50 psi. Any help would be appreciated.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
MTFCI Number: 13377
Re: Engine Miss
Post by Jim Sims » Sat Feb 08, 2020 12:09 pm
First find which cylinder is mis firing by shorting out each plug with a screw driver. Then check to see if you have a short in the coil box.
Chris Instness
First Name: Christopher
Last Name: Instness
* REQUIRED* Type and Year of Model Ts owned: 1915 runabout, 1923 speedster
MTFCA Number: 52552
Re: Engine Miss
Post by Chris Instness » Sat Feb 08, 2020 12:15 pm
Is it a constant miss or occasional or while accelerating?
wayne thompson
First Name: wayne
Last Name: thompson
Re: Engine Miss
Post by wayne thompson » Sun Feb 09, 2020 4:04 pm
Occasional after checking the spark plugs all seem to be firing ok.
70shovelhead
First Name: Preston
Last Name: Wells
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
Board Member Since: 2008
Re: Engine Miss
Post by 70shovelhead » Sun Feb 09, 2020 5:27 pm
Check for a broken or weak valve spring
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Re: Engine Miss
Post by bobt » Mon Feb 10, 2020 5:39 am
Check the firing order 1-2-4-3
Peter, Memphis TN
First Name: Peter
Last Name: Claverie
Re: Engine Miss
Post by Peter, Memphis TN » Mon Feb 10, 2020 10:22 am
I vote for a come-and-go short inside the coil box. Or a bad connection inside the coil box.
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Re: Engine Miss
Post by Moxie26 » Mon Feb 10, 2020 11:15 am
You said you installed new buzz coils?.... I would ask you to contact someone who is knowledgeable in your area to calibrate coils not only for electrical values but also the physical positioning of the upper hardware and points..... Sometimes you do get a ignition miss especially noticeable at idle because the points are physically too close together.
Ron Patterson
First Name: Ronald
Last Name: Patterson
Re: Engine Miss
Post by Ron Patterson » Mon Feb 10, 2020 11:39 am
Wayne
Have you recently driven the car in the rain or has it somehow gotten wet
Ron Patterson
