Rocky Mountain brakes
Posted: Sat Feb 08, 2020 4:42 pm
by Don ellis
Is it possible to get these things to not drag?
Re: Rocky Mountain brakes
Posted: Sat Feb 08, 2020 6:10 pm
by Scott_Conger
Not really, but if it is truely noticable ao a real extent, then something is maladjusted, which may be why you're asking.
For starters, I'd move the stay bars back and retighten the lock nut. They should not be set with zero clearance on the brake band tabs. The bands should be able to float fore/aft on them in all circumstances from fully "off" to fully "on".
Posted: Sat Feb 08, 2020 7:48 pm
by RajoRacer
Scott - the installation & adjustment docs. that come with the repro R.M. brakes from Bud say to adjust them just as Don has them. The instructions also state to attempt to set a clearance of approx. .030 all around which involves slight manipulation of ALL the mounting & hardware points !
Posted: Sat Feb 08, 2020 8:00 pm
by Henry K. Lee
Your rear supports are a little to perfect. Need to loosen the nut and recenter in the slots. This should do the trick.
Hope this Helps,
Hank
Posted: Sat Feb 08, 2020 9:30 pm
by Don ellis
Thanks I’ll give it a shot.
Posted: Mon Feb 10, 2020 5:49 pm
by TWrenn
An item to not overlook is the brake rods. I was able to get mine pretty much drag free by a lot of tweaking of them but seem to be great now.
