FORDLOC key needede
Posted: Fri Feb 14, 2020 10:14 pm
by Chris Haynes
I just bought this FORDLOC. Does anybody know where I could get a key made?
Re: FORDLOC key needede
Posted: Sat Feb 15, 2020 9:11 am
Find a locksmith, one with old time skills, they are around.
Web search found this one near you , site says they can make key for most, just call and describe the tumbler and item, might just do it. Or if questioned might know who can in their field. Only a good locksmith can do this.
https://www.securityunlimitedlocksmithl ... placement/
Posted: Sat Feb 15, 2020 12:17 pm
by Chris Haynes
The key and its operation for the FORDLOC is totally different. The lock operates by the key being pushed into the tumblers. Here is a picture I found online of what the key looks like.
Posted: Sat Feb 15, 2020 1:06 pm
Chris does your lock have the same numbers on it like the one you have? If the numbers are different and if it’s a 4 digit number it’s probably the key depth code for the lock. If it’s the same it could be just a part number for the lock.
It’s a good thing you found that picture of a key. Now you can go by that or have a locksmith to determine what width and depth the key needs to be. That picture will really help. It shouldn’t to difficult to make the blank if you have to since you know what it looks like.
Posted: Sat Feb 15, 2020 2:27 pm
Chris
Fortunate to have that photo of key, as John noted, the tumbler is 'six lever' type, as described in this old adv. from 1916 auto supply catalog.
Posted: Sat Feb 15, 2020 2:29 pm
by Benp
Yes, the picture could help a LOT. That key is pretty distinctive. I’d recommend trying to find an original before investing in a locksmith (sorry locksmith’s).
I don’t have any idea what year your lock was made (1920’s?) but early locks didn’t use too many different series — if any different.
Just recently I renewed effort to find an original key for my pre-1920 non-Ford car. (It’s one of the ‘magneto keys’ pictured on the chart below - not even saying which one) The car hadn’t had the correct key for 50 years, but we found some old ‘barrel’ keys and handcuff keys that could work IF you really played with them.
You can’t go into an antique’s shop without finding a jar of old keys - but that was worse than looking for a needle in a haystack.
Occasionally one would turn up at Hershey with an insane ($100+) price on it. But the value in any old key is in identifying it.
Turns out eBay is the place to go for these old keys. The trick is to search not for what it is — but what it looks to like people now. In my case a search for ‘barrel keys’ narrowed it down to 9,000 from 17,000 ‘vintage key’ listings. Took about 3 hours and a pair of reading glasses, but eventually I found these very rare early keys turn up regularly. Always in a large mixed lot. People have no clue what they are for. A friend told me, “Keep your MOUTH SHUT and bid on the WHOLE lot and you can get them pretty cheap. They turn up all the time.”
After getting burned a few times, I learned this was true. As rare as they may seem, they do come up regularly.
I learned to be PATIENT and hone in my eBay bidding skills. These lots never come up with a ‘buy it now’ price. Learned to make a low bid ($1 over starting) when first sighted to keep some hyena from convincing the seller to end the auction early. Near the end of the auction up your bid to the maximum you’re willing to pay (I’d say no more than $30 for the typical lot of 20. Could probably turn around and resell the same lot -1 for exactly what you paid). Your only competitors will be ‘steampunkers’. There’s no telling what in a lot may appeal to them - but it certainly won’t be that boring flat key. I lost a few lots before figuring that out and reacted poorly by bidding way too much later. On a good note, my venting of frustration with competing with steampunkers led to the accidental finding of an NOS key. Once I learned not to let the flaky steampunkers get to me I also picked up enough keys for everyone in my club who didn’t have one.
It is findable, only question is which you more willing to invest: Time or money?
Good luck,
Ben P.
Posted: Sat Feb 15, 2020 2:39 pm
Adv. for that model throttle and spark lever lock. Note the key is called a 'push key'. :)
35% Automobile Supply Co, New York. 1915
Posted: Sat Feb 15, 2020 4:08 pm
by Benp
Oh, I have to partially take that eBay hunt recommendation back. A quick google image search revealed that these Fordloc’s were produced to different series which complicates things. That picture won’t match the key unless you have the s/n off the lock.
This one off a google search looks like Y57 - totally different key. Does your lock have a #? If it does, and you can find a photo of same with a key - eBay would be doable. Without — locksmith would be the cheapest way.
Darn.
Posted: Sat Feb 15, 2020 5:10 pm
by Jim Eubanks
I have one of those but its a SBCO Crank brand. Been wondering what it fits.
Posted: Sat Feb 15, 2020 8:47 pm
by Chris Haynes
There is no number visible in the pictures. They only show one side. Hopefully I will have it in my hands in a few days.
