Exhaust pipe
Posted: Sun Feb 03, 2019 11:01 am
This post goes with the one on the exhaust nut wrench.
One reason the exhaust nut gets loose is because someone uses a clamp on the front end of the muffler where the pipe attaches. It is best to leave it without a clamp so that the pipe is free to rotate or move in and out of the muffler as the car vibrates and twists when driving. A clamp under the nut will also help keep the nut from backing off.
