The Future meets the Past
Posted: Thu Feb 20, 2020 8:25 pm
by fbergski
I'm stuck in two times, the past and the future. While I own two model t's I work in Aerospace making high tech components. So naturally I like to apply my knowledge to the past. Last year we bought a 3D plastic printer at work to try out, at first I was skeptical that we could find a use for it. After a couple of months is came apparent it was quite handy to design a fixture in 3D then print it out in plastic for fitting purposes. Now we have three of them and they run all day long making disposable fixtures and tooling affordably.
So with that I bought a 3D printer for home use, The attached pictures shows the printer and a tool I printed out to push the piston rings into the cylinder bore evenly. I plan to make more tools and plastic bits for the car. There are many types of plastics to chose from, no structural parts for now.
1410
1411
Re: The Future meets the Past
Posted: Thu Feb 20, 2020 10:18 pm
by Kuhner
What brand and model printer ?
Posted: Thu Feb 20, 2020 11:31 pm
by RustyFords
Very very neat. Good for you.
Posted: Fri Feb 21, 2020 12:31 am
by fbergski
Creality Ender 3D Pro
Posted: Fri Feb 21, 2020 7:45 pm
by Gene_French
Philip:
I have thought of using a 3d printer to produce foundry patterns … with proper software the image could be mirrored and shrinkage added to the printed pattern … just a thought … glad I am retired from manufacturing … way too complex ( or simple ) for me sometimes … always an optimist ...Gene French
Posted: Fri Feb 21, 2020 8:07 pm
by KWTownsend
Philip-
This is so cool.
I wonder what Model T could be reproduced using a 3-D printer?
Maybe the hard rubber ignition switch? Terminal block? Combination horn button/headlight switch?
Posted: Fri Feb 21, 2020 8:31 pm
by fbergski
I already made a prototype front switch plate for my Heinze coil box. I need to get the correct material for the production version.
