Tobin Arp thrust facing tool
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Feb 23, 2020 3:31 pm
So I have been “commissioned” to copy my Tobin Arp thrust facing tool. It is a very nice design as you can move the cutting tool radially as it spins. The TA is 1-1/8” diameter boring bar.
Just wondering if any one else needs one.
I am contemplating making one also for myself that is on a 1” boring tool for my T line boring outfit
I know some people just face the cap in a lathe but I prefer having a full diameter thrust face
Andy Loso
First Name: Andy
Last Name: Loso
MTFCA Number: 346
MTFCI Number: 119
Re: Tobin Arp thrust facing tool
Post by Andy Loso » Sun Feb 23, 2020 7:25 pm
Pictures, please.
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Sun Feb 23, 2020 8:44 pm
Les, I could be interested. I'd like to see your design. Would It be for a Tobin Arp TA 14 ?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Feb 23, 2020 9:02 pm
Bill
Yes for a TA 14
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Mon Feb 24, 2020 1:41 am
Les, I would like to have one for my TA14. Count me in.
Last Name: Gregush
Post by Mark Gregush » Mon Feb 24, 2020 2:13 am
I know if you have to ask how much it cost you can't afford it, but I am going to ask anyway. ;) Would it work with the KR Wilson boring bar?
When I had my block done it got the full face thrust also.
1921 Huckster
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Feb 24, 2020 12:45 pm
Bill and Eric
Thank you I will put you on the list
Cost
So far I am sourcing the components and talking to shops that can help with the project.
A project like this reminds me of the old joke;
“It’s a bit like buying hay, if you want top quality you need to pay a fair price, if the stuff that has been through the cow once is good enough, well that is considerably cheaper “!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 25, 2020 11:33 am
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat Mar 07, 2020 7:33 am
Les: Will parts be available? Will your parts work with an original? I have part of one. Thanks Dan
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 07, 2020 11:50 am
Dan
My plan is to make it functionally identical. The tool holder will be identical for sure as well as the controller.
I don’t want to disassemble the original one so I will guess a bit on the internal design.
I have finally succeeded in finding sources for the components and materials. Now to finalize the drawings!!
RxGPoblet
First Name: Garland E
Last Name: Pobletts
Post by RxGPoblet » Sat Mar 07, 2020 1:14 pm
Hey all,
Forgive my ignorance. Kinda new to the repair end of a T. What is this tool used for?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 07, 2020 1:53 pm
Garland
The crank bearings of old engines are generally poured Babbit which is machined in place to fit the crank. One of the bearings (usually the rear one) controls the end float. This is a cutting tool for facing these surfaces.
I hope this helps
RxGPoblet
Last Name: Pobletts
Post by RxGPoblet » Sat Mar 07, 2020 2:36 pm
Got it. Thanks.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Mar 13, 2020 12:30 pm
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Mar 13, 2020 12:54 pm
Dan
I saw that one last night. Unfortunately it is missing a part (which I see is advertised separately for $600.00), the “stability disc”(I will call it that)!
I have finally sourced the components that I can buy. Now to complete the drawings and start making the other bits. It appears that probably I should make twice as many tool holders and “stability discs”, as tool holders for sure get “lost “ over the years.
Right now it seems like 3 complete assemblies.
My target is about $1,000.00 each, but we will see!
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Mar 14, 2020 1:00 am
The official name for the "stability disc is "Tool Holder Assembly" and the current part number was TA-950. The old part number for this was TA-B1130A.
As you probably know its serves two purposes- 1) a stabilizer for the facing tool and 2) a tool extension for large bores that were past the range of a long toolbit. With the tool mic at zero and on the extension, the tool would be set for a 4.125" bore or thereabouts. It seems odd, but my TA-14 manual has no mention of the Tool Holder Assembly or its use.
