Radiator Heights
Posted: Sun Feb 03, 2019 5:49 pm
by Tom Stephens
I'm trying to find the height dimension from the top of the crank handle (where it goes into the motor in front) to the top of the radiator shell (not including the filler neck) for the 1915-16, 1917-23, and 1924-25 radiators.
I would appreciate it if those who have those year radiators could give me some actual measurements off of your cars.
Thanks!
Tom
Re: Radiator Heights
Posted: Sun Feb 03, 2019 5:59 pm
by Steve Jelf
From the top of the crank handle to the top of the shell on my 23 is 23½". For 24 and later you can add about an inch to that. I have the radiator off my 15, so I can't help on that one.
Posted: Sun Feb 03, 2019 6:12 pm
by Mark Gregush
What are you trying to figure out? 1917-23 23-5/8" and 1924-25 25-1/4" These are approx. As you can see there is different measurements for different cars.
Posted: Mon Feb 04, 2019 11:28 am
by Tom Stephens
Thanks Steve!
Mark, I am trying to figure out how much lower the '15-'16 radiators are than the '17-'25s. You both have done well on those last years, now I hope someone can chime in with the '15-'16s.
In all the threads I found on radiator measurements, where to measure from at the bottom of the radiators caused many differences. I thought if I can use the fixed top of the crank handle (where it goes into the motor in front), I would get less variation from car to car.
Tom
Posted: Mon Feb 04, 2019 11:46 am
by Chris Instness
I've got 21 3/8th in my 1915.
Posted: Mon Feb 04, 2019 11:57 am
by Tom Stephens
Chris, is yours a black (later style) or brass radiator?
Tom
Posted: Mon Feb 04, 2019 12:22 pm
by Mark Gregush
15 would be brass.
Posted: Mon Feb 04, 2019 12:31 pm
by Tom Stephens
Mark,
Per Chris's avatar, he might have a '15 motor, but that speedster has a black radiator.
Tom
Posted: Mon Feb 04, 2019 12:38 pm
by Mark Gregush
21+" sounds about right for a brass radiator. You will note the difference between the number I gave for the low black radiator(17-23) and that number. The 15 to about 18, the radiator sat on leather pads only under the mounting ears. Then from about 18 up there were springs in cups in the mounting ears. Depending the crush of the springs, the measurements can vary.
I would think a better measurement would be from the top of the frame rails up which would be a little more hard to get with the shell in place. Chris list both a 1915 and a speedster in his profile and the avatar shows the speedster from the rear.
Posted: Mon Feb 04, 2019 12:58 pm
by Chris Instness
My 15 is a brass radiator.
Posted: Mon Feb 04, 2019 1:09 pm
by Chris Instness
Posted: Mon Feb 04, 2019 1:34 pm
by Tom Stephens
Thanks guys, EXCELLENT! I keep seeing '15 speedsters and they always look a lot lower than the black radiator ones. I had no idea that the brass radiators were THAT much lower. Positive proof.
I appreciate the info!
Tom
Posted: Mon Feb 04, 2019 3:10 pm
by Tom Stephens
Chris, I sent you a PM.
Tom
Posted: Mon Feb 04, 2019 6:23 pm
by Mark Gregush
Also having a dropped front axle lowers the front too. Many are setup that way when it comes to speedsters.
Posted: Mon Feb 04, 2019 6:39 pm
by Tom Stephens
Mark,
Yes, what you said
Check your PMs too.
Tom
