Scat crank insert rod shells
Posted: Tue Feb 25, 2020 11:53 am
by Les Schubert
I am considering using a set of these shells as I have a custom T crank with 1-1/2” journals. The crank is stock stroke and pressure oiled and I will be using some custom connecting rods. I believe the Scat rods with this size journal are only for the stroker crank?
If someone could provide me with the rod big end diameter that these shells fit it would be appreciated???
Thank you
