				OT Fastenal shipping
				Posted: Mon Feb 04, 2019 10:14 am
				by Ruxstel24
				I am trying to get a quote to ship a steering column to TX and thought maybe Fastenal would be a good option. Never used them before.
No steering wheel, just the column. Filled out the online form...got a quote of $232.55 !!!!
I called a spoke with a girl that explained the size was the issue, blah blah.
Does this sound right to those of you who have used them ?
Next stop FedEx !
				Re: OT Fastenal shipping
				Posted: Mon Feb 04, 2019 10:41 am
				by Original Smith
				You might check Greyhound too.
				Posted: Mon Feb 04, 2019 10:57 am
				by Tom Hicks
				I have shipped two engine with transmissions half way across country for $125 and $150.  Each was on a 4 X 4 pallet.  Weight is not the issue, it is the dimensions of the package.
BTAIM, your quote sounds way high.
				Posted: Mon Feb 04, 2019 2:03 pm
				by Russ T Fender
				I shipped 6 wire wheels strapped to a pallet from Washington State to Florida for under $200 with Fastenal.  No issues.  I'd check with them again, something does not sound right.
				Posted: Mon Feb 04, 2019 2:45 pm
				by Humblej
				Russ, did you look into USPS or UPS? USPS will go up to 130" length plus circumference for the oversize rate.
				Posted: Mon Feb 04, 2019 2:58 pm
				by Ruxstel24
				I was going to try FedEx first, they are usually cheaper for larger items.
I need to find a box it will fit in and go from there. And pop the wheel off.
Thanks, I can't believe it is a correct quote.
I'm thinking maybe $40 with FedEx...
				Posted: Mon Feb 04, 2019 3:09 pm
				by Jim_PTC_GA
				I used them for the first time last year to ship a pallet of fenders. Very satisfied with their service and cost.
One thing they don't tell you out right is that if the parts aren't enclosed in a crate their not insured. Its in the small print.
				Posted: Wed Feb 06, 2019 7:17 pm
				by Tmodelt
				I sometimes ship long skinny parts in pvc pipe with threaded end caps. Very rigid packaging with no damage. Can be reused for the return shipment too.
