Nickel Plated Bolts
Posted: Mon Jan 07, 2019 12:04 pm
by mytractor
Hello:
Working on a 1927 Coupe and wondered if someone could tell besides the head bolts which bolts on the engine need to be nickel plated.
Thanks Steve
Re: Nickel Plated Bolts
Posted: Mon Jan 07, 2019 12:16 pm
by Humblej
The 2 bolts for the water outlet/fan bracket, and 2 bolts for the water inlet are dome shaped head nickle plated bolts like the head bolts.
Posted: Mon Jan 07, 2019 12:54 pm
by Ed Baudoux
I believe the manifold clamp bolts are nickel plated on the Improved Ford as well.
Posted: Mon Jan 07, 2019 5:25 pm
by DanTreace
Walter T. Fishleigh's files in Acc. 94 at the Ford
Archives there is a memo dated July 26, 1926.
Nickel Plate used on:
Cylinder Head Cap Screws
Spark Plug caps and Thumb Nuts
Spark Plug Wire Terminals
Coil Box Terminal Bolts and Nuts
Water Connection Cap Screws
Manifold Cap Screws
Bright Zinc Plate used on:
Cut Out Cover
Moleskin Pyroxylin Used on:
Cylinder
Cylinder Head
Generator Bracket
Front Cover
Air Intake and Manifold
Posted: Mon Jan 07, 2019 6:20 pm
by mytractor
Thanks all for the information.
