Front floor board
Topic author - Posts: 9
- First Name: Jim
- Last Name: Poindexter
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Touring
Front floor board
What is the easiest way to make your own front floor board.. 1924 Ford Touring. Thanks for the help
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Front floor board
Borrow one and copy it.
- First Name: Art
- Last Name: Taylor
- MTFCA Number: 22512
I first made a template out of cardboard. I shaped the cardboard using a band saw and drill hole. After, creating a pattern I used it to make my wood floor.
If you need more information contact me.
Art Taylor
Art Taylor
- First Name: Jim
Thanks for the imformation, my problem is my motor is in another state being rebuild. It won't be back till end of the year. I am trying to have the car finished when it get back. That why I can't make a pattern. I thought there might be a blue print out their. This is my first t project.
- First Name: Jim
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
http://www.mtfca.com/discus/messages/70 ... 1491253670
http://www.mtfca.com/discus/messages/80 ... 1257864007
http://www.mtfca.com/discus/messages/29 ... 1170296383
http://www.mtfca.com/discus/messages/25 ... 1353988848
- Last Name: Bartsch
- MTFCA Number: 30615
Jim: Here is a print of the bottom board, the one in front of the seat, from the Funprojects website. I suspect this one is the 'easiest' one to make. best, jb
http://www.funprojects.com/pdf/T1404B.pdf
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
Art,where were you a couple years ago with that "tip'? I scratched my head bare trying to figure it out and finally just decided 1 day to lay some boards together,make it way to wide and trim it down.
- First Name: Art
- Last Name: Taylor
My son and I glued the board together and trim the board using the pattern. Good luck Jim.
Art
Art
- Last Name: Blaydon
The best way is to buy them from Jon Anderson. They are exact to the factory specs and fit perfect.
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
Jim, I would like to ask did you not have a floor boards when you acquired your car?
Something I have seen is a pre 1925 T that has had a 1926-7 pedals, transmission cover or even a complete engine assembly. The pre 1925 pedals can be bothersome because they are narrow. I am saying this because the pedal spacing on the 1926-7 is different and requires a custom floor board.
- MTFCA Number: 121
- MTFCI Number: 16310
Getting them from Jon is the best idea. If not, find originals to copy, and be sure to rabbet the front and back sides. They were never varnished.
- Last Name: Nunn
- MTFCA Number: 50321
Don't expect dimensional lumber to fit. For my '26 Runabout I had to plane the boards to 9/16" to fit into the body's flanges and under the front board hold-down. The white panel in the photo is a piece of 1/4" hardboard that I used as a template for the upper board.
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
Here's mine made from Poplar. So close they'd only fit this car. Your problem is no eng/trans in place. I'd definitely wait for it to be back in place. Anything else would be a crap shoot.
