Another odd early carburetor part, what is this ?
Topic author - Posts: 1654
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
Just going through the box of carburetor parts and also found this one, any ideas? Bob
- Last Name: Meixner
- MTFCA Number: 28023
- MTFCI Number: 20471
Re: Another odd early carburetor part, what is this ?
Is that the piece for a late 31 Zenith?
- First Name: Jonathan
- Last Name: Bodine
- MTFCA Number: 4006
Looks like an early version of a banjo fitting.
- Last Name: Osterman
One of my banjos.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Its part of a gas inlet fitting. Its missing the hollow bolt that fits thru the two large holes and screws into the gas inlet of the carburetor.. There will be a gasket on each side of the part at the large holes to seal the hollow bolt. This part swivels to any position to make hooking up the gas line easier to hook up. Some model As and many accessory carbs used this style of fitting.
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
It is a Stromberg fuel inlet. It mounts to the bottom of many of the larger M and O series carburetors with a through bolt. Originally it would have a cone shaped fuel screen inside.
- First Name: Ed
- Last Name: Martin
I would guess it’s the fuel inlet off a Winfield carburetor or similar.
- First Name: Stan
- Last Name: Howe
It is not for a Winfield.
It is what is commonly called a banjo fitting for a Stromberg O, L or M series carburetor.
www.strombergof.com
I'm well over 1000 Stromberg rebuilds, this fitting is part of the conversion to modern needle and seat that I make for Stromberg O, L, M series carburetors that do not use the later style inlet.
But whatever.....
www.strombergof.com
But whatever.....
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
It's a novel approach. No gaskets!
A spare Stromberg M-3 here.
Poop, can't post pics today I guess...
- First Name: Duane
- Last Name: Cooley
Try again.
