Another odd early carburetor part, what is this ?
Posted: Sat Mar 14, 2020 9:59 am
by FATMAN
Just going through the box of carburetor parts and also found this one, any ideas? Bob
Re: Another odd early carburetor part, what is this ?
Posted: Sat Mar 14, 2020 10:07 am
by got10carz
Is that the piece for a late 31 Zenith?
Posted: Sat Mar 14, 2020 10:29 am
by Mark Osterman
One of my banjos. ๐Ÿ˜€
Posted: Sat Mar 14, 2020 10:31 am
by dobro1956
Its part of a gas inlet fitting. Its missing the hollow bolt that fits thru the two large holes and screws into the gas inlet of the carburetor.. There will be a gasket on each side of the part at the large holes to seal the hollow bolt. This part swivels to any position to make hooking up the gas line easier to hook up. Some model As and many accessory carbs used this style of fitting.
Posted: Sat Mar 14, 2020 11:31 am
by StanHowe
It is a Stromberg fuel inlet. It mounts to the bottom of many of the larger M and O series carburetors with a through bolt. Originally it would have a cone shaped fuel screen inside.
Posted: Sat Mar 14, 2020 11:41 am
by ThreePedalTapDancer
I would guess itโ€™s the fuel inlet off a Winfield carburetor or similar.
Posted: Sat Mar 14, 2020 12:01 pm
by StanHowe
It is not for a Winfield.
It is what is commonly called a banjo fitting for a Stromberg O, L or M series carburetor.
www.strombergof.com
I'm well over 1000 Stromberg rebuilds, this fitting is part of the conversion to modern needle and seat that I make for Stromberg O, L, M series carburetors that do not use the later style inlet.
But whatever.....
Posted: Sat Mar 14, 2020 3:26 pm
by Duey_C
It's a novel approach. No gaskets!
A spare Stromberg M-3 here.
Poop, can't post pics today I guess...
Posted: Sat Mar 14, 2020 3:29 pm
by Duey_C
Try again.
