Spark Plug adapters
Topic author - Posts: 1049
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Spark Plug adapters
The spark plug adapters from 1/2" pipe thread to 14mm are available, but what it you have a head tapped for 14mm and want to use standard T 1/2" pipe thread plugs? I guess you're screwed. I'd like to add an explosion whistle, but I don't know of any adapters for 14mm plugs.
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Re: Spark Plug adapters
You could just drill and tap to the pipe threads. A 1/2 - 14 tap would require a 23/32 drill.
1912 Torpedo Roadster
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
Or get a different head.
- First Name: Terry
- Last Name: Woods
If I knew there was enough metal around the 14 mm plug holes without causing problems, I'd drill and tap.
- MTFCA Number: 52564
A friend has a Z head with the 14mm plugs. He would like me to drill and tap for 1/2 plugs, but how much metal (aluminum) has been my concern as well. Chances are there is, but really don't want to mess it up.
1920 Dodge touring
1920 Dodge touring
- First Name: Kevin
- Last Name: Pharis
I would expect that if the head was originally sold with either spark plug option, there would be more than enough material to support the larger plug variety. I highly doubt there would be a separate pattern just to accommodate the relatively minor dimensional change between the 14mm and the 1/2” NPT plugs
