Spark Plug adapters
Posted: Mon Mar 16, 2020 11:46 pm
by ModelTWoods
The spark plug adapters from 1/2" pipe thread to 14mm are available, but what it you have a head tapped for 14mm and want to use standard T 1/2" pipe thread plugs? I guess you're screwed. I'd like to add an explosion whistle, but I don't know of any adapters for 14mm plugs.
Re: Spark Plug adapters
Posted: Tue Mar 17, 2020 2:37 am
by SurfCityGene
You could just drill and tap to the pipe threads. A 1/2 - 14 tap would require a 23/32 drill.
Posted: Tue Mar 17, 2020 9:20 am
by tmodeldriver
Or get a different head.
Posted: Tue Mar 17, 2020 10:57 am
by ModelTWoods
If I knew there was enough metal around the 14 mm plug holes without causing problems, I'd drill and tap.
Posted: Tue Mar 17, 2020 12:18 pm
A friend has a Z head with the 14mm plugs. He would like me to drill and tap for 1/2 plugs, but how much metal (aluminum) has been my concern as well. Chances are there is, but really don't want to mess it up.
Posted: Tue Mar 17, 2020 12:25 pm
by Kevin Pharis
I would expect that if the head was originally sold with either spark plug option, there would be more than enough material to support the larger plug variety. I highly doubt there would be a separate pattern just to accommodate the relatively minor dimensional change between the 14mm and the 1/2” NPT plugs
