Chassis paint question
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Tue Mar 17, 2020 6:17 pm
I did a forum search with no luck. I think there was a thread about chassis paint. From what I remember, it was a brush on paint that would not show brush marks and was hard as nails.
Can anyone point me in the right direction?
Shane Lach
First Name: Shane
Last Name: Lach
Re: Chassis paint question
Post by Shane Lach » Tue Mar 17, 2020 6:28 pm
mtntee20
First Name: Terry & Sharon
Last Name: Miller
MTFCA Number: 32583
Post by mtntee20 » Tue Mar 17, 2020 7:01 pm
You also have POR 15, and Chassis Saver. I have used both of these and can recommend either but I like the Chassis Saver more. It's thicker paint
Good Luck,
Terry
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Wed Mar 18, 2020 6:34 pm
Gentlemen, Thank you!
fordorgalore
First Name: Don
Last Name: Booth
Post by fordorgalore » Wed Mar 18, 2020 6:38 pm
Marty, I use Automotive Grey Rustbullet for the primer and Blackshell Rustbullet for the black finish. Its as close to powder coating as you can get. It can be ordered thru www.rustbullet.com.
mtntee20
Last Name: Miller
MTFCA Number: 32583
Post by mtntee20 » Wed Mar 18, 2020 7:02 pm
Thought must be taken as to the rustproofing put on a frame.
It must be high quality to last, to adhere, and to prevent rust. A very important consideration: Seeing cracks, should they develop, BEFORE they grow to failure.
Powder coating is great in a lot of places but cracks can develop under the powder coat and not be visible until it's too late. I considered spray on truck bed liner. Same disadvantage. A good quality rust paint is the answer I believe. Your mileage may vary and I respect your choices. I'm just trying to enlighten my Model T buddies.
Good Luck,
Terry
rgould1910
Last Name: Gould
Post by rgould1910 » Thu Mar 19, 2020 12:36 pm
I used brush on POR 15 reluctantly because I thought the brush marks would show. They don't. I was very impressed. I used a quality bristle brush on a sanded but not sandblasted frame if that makes a difference. In the past I've sprayed DP 90 epoxy primer, but this POR 15 has that beat hands down.
Post by Mark Gregush » Thu Mar 19, 2020 12:52 pm
While Rustolium does not stay shinny that is what I used. Has held up just fine for over 15 years. Wire bushed the frame, used Rustolium rusty metal primer and black over that.
1921 Huckster
MTFCA Number: 1219
Post by Rich Eagle » Thu Mar 19, 2020 1:25 pm
I like Van Sickle enamel. https://www.vansicklepaint.com/ It flows on well and is fairly durable. It is inexpensive compared to many paints. It does dry slow and does not have a high gloss but an original look to my eyes. I use Por 15 for inside panels as it has poor UV resistance. Rustolium is also nice but slow drying. The slow drying lets the brush marks flow out.
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Fri Mar 20, 2020 6:24 pm
Great suggestions! Now I gotta do my homework!!
Thanks!
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Mar 21, 2020 9:53 am
I've always used gloss black Rustoleum on all my cars. I spray it on. In fact, it's the first thing I do before I start assembling the car. Be sure to weld up any non original holes in the frame before painting.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Sat Mar 21, 2020 11:43 am
