Chassis paint question
Posted: Tue Mar 17, 2020 6:17 pm
by Marty Bufalini
I did a forum search with no luck. I think there was a thread about chassis paint. From what I remember, it was a brush on paint that would not show brush marks and was hard as nails.
Can anyone point me in the right direction?
Re: Chassis paint question
Posted: Tue Mar 17, 2020 6:28 pm
by Shane Lach
Posted: Tue Mar 17, 2020 7:01 pm
by mtntee20
You also have POR 15, and Chassis Saver. I have used both of these and can recommend either but I like the Chassis Saver more. It's thicker paint
Good Luck,
Terry
Posted: Wed Mar 18, 2020 6:34 pm
by Marty Bufalini
Gentlemen, Thank you!
Posted: Wed Mar 18, 2020 6:38 pm
by FordorGalore
Marty, I use Automotive Grey Rustbullet for the primer and Blackshell Rustbullet for the black finish. Its as close to powder coating as you can get. It can be ordered thru www.rustbullet.com.
Posted: Wed Mar 18, 2020 7:02 pm
by mtntee20
Thought must be taken as to the rustproofing put on a frame.
It must be high quality to last, to adhere, and to prevent rust. A very important consideration: Seeing cracks, should they develop, BEFORE they grow to failure.
Powder coating is great in a lot of places but cracks can develop under the powder coat and not be visible until it's too late. I considered spray on truck bed liner. Same disadvantage. A good quality rust paint is the answer I believe. Your mileage may vary and I respect your choices. I'm just trying to enlighten my Model T buddies.
Good Luck,
Terry
Posted: Thu Mar 19, 2020 12:36 pm
by RGould1910
I used brush on POR 15 reluctantly because I thought the brush marks would show. They don't. I was very impressed. I used a quality bristle brush on a sanded but not sandblasted frame if that makes a difference. In the past I've sprayed DP 90 epoxy primer, but this POR 15 has that beat hands down.
Posted: Thu Mar 19, 2020 12:52 pm
by Mark Gregush
While Rustolium does not stay shinny that is what I used. Has held up just fine for over 15 years. Wire bushed the frame, used Rustolium rusty metal primer and black over that.
Posted: Thu Mar 19, 2020 1:25 pm
by Rich Eagle
I like Van Sickle enamel. https://www.vansicklepaint.com/ It flows on well and is fairly durable. It is inexpensive compared to many paints. It does dry slow and does not have a high gloss but an original look to my eyes. I use Por 15 for inside panels as it has poor UV resistance. Rustolium is also nice but slow drying. The slow drying lets the brush marks flow out.
Posted: Fri Mar 20, 2020 6:24 pm
by Marty Bufalini
Great suggestions! Now I gotta do my homework!!
Thanks!
Posted: Sat Mar 21, 2020 9:53 am
by Original Smith
I've always used gloss black Rustoleum on all my cars. I spray it on. In fact, it's the first thing I do before I start assembling the car. Be sure to weld up any non original holes in the frame before painting.
Posted: Sat Mar 21, 2020 11:43 am
by Tim Rogers
