A dual plug ignition system
Topic author - Posts: 1319
- First Name: Les
- Last Name: Schubert
- First Name: Les
Re: A dual plug ignition system
First picture is cap to Bosch distributor adapter
Next Nissan dual plug distributor cap
Finally Onan dual plug coil
- First Name: Les
- First Name: Les
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
That is just Cheating Les and you know it..., Damn Good Idea!
LOL
Hank
LOL
Hank
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I worked my butt off on a twin spark Nissan unit to get there!
Nice Work!
Hank
Nice Work!
Hank
- First Name: Mitchell
- Last Name: Helgeson
- * REQUIRED* Type and Year of Model Ts owned: 1925 speedster
I am very interested in this dual ignition. I am haveing trouble completely understanding what you are doing to accomplish this. I would really appreciate a few more clearer pictures and possibly some instructions to help.
Thanks for any and all help
Mitchell
Mitchell
- Last Name: Pharis
I’m not sure that the 009 conversion is “cheating”... but sure is a loooooooot simpler than the other options...
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Why go to all that work when you can buy a Nippon Denso Nissan distributor from Advance auto parts for about $125.00. I did that for my dual spark Fronty head. just had to do a tiny bit of machine work to accept the dist drive gear and it fit right in. It comes with out a vacuum advance but centrifugal weights.
frontyboy
frontyboy
- First Name: Les
Dick
I understand your concept I think.
Please explain how you have “energized” the production of the spark. I suspect that the Nissan distributor is for electronic ignition, so I guess that you have also incorporated all the relevant parts over just buying the distributor?
In my case I used a distributor that bolts onto the T. Made two simple adapters and bought a available coil that is designed to fire two plugs at the same time. Simple basic ignition system!
- First Name: DAN
- Last Name: MCEACHERN
The Nissan twin spark fires two standard 12 volt ignition coils. Modifying the distributor body is about the same amount of work as making the 009 body fit in a Bosch front plate. You do need reverse rotation gears, but I know a guy that makes those.
- First Name: Les
Dan
So who makes the gears. I’m trying to get a couple of cam gears for my timer elevators and have had NO success.
Thank you
Thank you
- Last Name: Pharis
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
It's pretty easy to adapt the nissan distributor to a Bosch plate. It's easier to plug one set of holes and run single plug ignition, highly doubt you would notice a difference. A T overhead has a pretty open chamber, flame travel shouldn't be an issue. I run single plug and it's fine.
Andy
Andy
- MTFCA Number: 14972
- MTFCI Number: 15411
I'm going to have to disagree with you Andy regarding the comment of "highly doubt you would notice a difference" - I'm running the Nissan and fire all 8 plugs with twin ignition coils & switch on my BB RAJO- I have my fuel pump hooked up to the intake side of the switch and if I shut off the exhaust side plugs, the r.p.m. drop quite noticeably !
- First Name: dick
- Last Name: dock
I have not run mine yet as I'm about a year away from completion. I think what rajo said above, dual coils and the Nissan distributor
is easy peasy and I like easy peasy. Seems everyone falls in love with the oo9 Bosch but its a 50 year old design and I like easy and a far better design as far as I am concerned.
my opinon and 25 cents won't get you coffee at Micky D's
frontyboy
frontyboy
- First Name: Les
All I will say is I spent at most 2 hours making the two parts to convert the Bosch front plate distributor. I consider that pretty “easy peasy”.
Anyway have a great day and all the best
- Last Name: Pharis
Les, I’m wondering about the Onan coil...? Is it for a 2 cylinder engine with waste spark ignition?? Or is there 2 separate coils cast into one housing?? Do you intend to add a second set of points to the 009??
- Last Name: Clary
Steve, the nissan distributor doesn't fire both plugs at the same time. It's been a while since I dealt with one but I think the difference is around 5 degrees, you are probably shutting off the advanced bank. The Nissan ran the extra set of plugs for emissions, not performance.
Andy
Andy
- First Name: Les
Kevin
The Onan coil is for a two cylinder engine and fires a “waste” spark each time. The points run off of the crank shaft.
I realize the properties of the Nissan, Andy - I'm just stating that you can certainly "feel" the r.p.m. drop & increase when driving.
- Last Name: Clary
No worries Steve, not everyone is familiar with all the odd things the automakers tried in the 80's.
Andy
Andy
- First Name: Les
Kevin
If I am unhappy with the performance I would consider adding a second set of points and 2 conventional coils.
So it appears that the Nissan distributor version is kind of a “fake “ dual ignition as one plug fires too late to contribute any true benefit to performance
- First Name: Leo
- Last Name: van Stirum
A point of caution considering a "waste spark" ignition system :
Old engines from the early years of the century (and i consider our beloved Ts to be in that category) usually have quite a large amount of unburnt fuel in the exhaust gases, specially when still cold.
This combined with the often less than perfect scavenging has lead to more than one muffler exploding when the "waste"spark manages to ignite the gases in the exhaust system through the open exhaust valve,
Leo van Stirum, Netherlands
- First Name: Les
Leo
To correct your misconceptions, this system would not involve a waste spark when installed on a model T dual plug head
- First Name: Leo
I understood that Les, just posted this as a word of caution for other posters because some posters were discussing the 'waste spark' idea
