Guess what this is and what happened.
Posted: Sat Mar 21, 2020 8:04 pm
by ivaldes1
See if you can guess what this is and what happened.
Re: Guess what this is and what happened.
Posted: Sat Mar 21, 2020 8:13 pm
by Angmar
Is that seat material with some portion of a metal tab sticking out?
Posted: Sat Mar 21, 2020 8:15 pm
by got10carz
My guess, it's a crease in the upholstery, and something was jammed from behind. Must be a roadster.
Posted: Sat Mar 21, 2020 8:18 pm
by perry kete
Key stock that you forgot to include in reassembly
Posted: Sat Mar 21, 2020 8:24 pm
by Larry e rutt
Looks similar to this.... rats trying to pull the rat bait down their hole ... yes in the barn where I keep my model T
Posted: Sat Mar 21, 2020 10:27 pm
by jiminbartow
My first thought was that someone dropped a flash drive into the gorilla enclosure at the zoo and it is laying next to the concrete wall guarded by the occupant.
Posted: Sun Mar 22, 2020 12:31 am
by ivaldes1
Great answers! See the bigger picture. It is a Bendix key that went missing for 30 minutes when it fell out and silently wedged itself between the mechanics creeper head cushion and the creeper. I could not figure out where it fell including turning over the creeper (it did not fall out) until I carefully examined the creeper head cushion itself. It took pliers to extract it. -- IV
Posted: Sun Mar 22, 2020 6:59 am
by Henry K. Lee
WOW, That would have driven anyone nuts!
Posted: Sun Mar 22, 2020 9:08 am
by got10carz
Now I know what happened to mine. About 3 days ago the last part I put on a rebuilt motor was the starter. Had to rob another starter.
Posted: Sun Mar 22, 2020 10:06 am
by CudaMan
Those Bendix keys are a lively bunch, they seem to pop out of position at the slightest provocation. I found mine once on top of my transmission door screen, it got tossed up and caught by the magnet.
Without the key in place, all the starter force is taken by the spring bolts and they won't last more than a few starts before shearing.
It is nearly impossible to see or feel what the key is doing when you slide the Bendix onto the shaft.
I learned early on to check the fit of the key in both the starter shaft and the Bendix head to insure that the head can slide on the shaft smoothly without pushing the key out of its slot in the shaft. If I ever have to replace it again I'm tempted to use some loctite to affix the key into the starter shaft slot and let it cure before sliding the Bendix on.
Posted: Sun Mar 22, 2020 12:38 pm
by Jeff5015
It looks like a bendix key wedged in the crease of a creeper head cushion.
Posted: Sun Mar 22, 2020 3:42 pm
by ivaldes1
How did you know???!!!!
Jeff5015 wrote: ↑Sun Mar 22, 2020 12:38 pm
