New Day Timer very advanced and walking
Posted: Tue Mar 31, 2020 2:00 am
Hi all-
Have been around for a couple of years but had to re-register.
I've searched old forums, I swear.
I have just replaced the Kent-Atwater my (one and only first) T came with with coils. Actually got it running very sweetly.
BUT the apparent rod location (the 2.5" recommendation and I do have the tool) at full retard seems much too retarded to even start. And sweet idle is sufficiently advanced that the blue wire is almost in the fan belt. Easily 3.5". Runs great though.
Weirder is this: even though the brush arm is flush up against, well, whatever is there and the timer sits flat when installed, when running the damn thing wobbles like mad. The tension doesn't seem exceptional although ive shortened the spring on the brush and further tensioned the retaining arm.
Is my brush arm out too far? Is there a vestigial disc or fitting from the distributor I havent extracted? Any experience with either this advance issue or walking timer? Must also be said that the drag seems to be enough that my old sloppy spark rod actually gets pulled to retard by the running engine. Also I did have to clearance the brush arm a bit for the pin, but the pin was too large for the slot in the arm. Problem is, I cant find evidence or images of what should really be behind that arm on the camshaft... would love a blow-up of the whole stack in there appropriate for a New Day timer.
Still, the advance distance....
Thanks hive-mind!
ACP
Thanks hive-mind!
ACP
