Voice of Experiance Wanted
Posted: Fri Apr 03, 2020 5:45 pm
Have any of you good folks out there ever attempted to or better yet, had a positive outcome in replacing the rear spring U-bolts under a closed car, such as a Centerdoor without lifting the body ??????
Re: Voice of Experiance Wanted
Posted: Fri Apr 03, 2020 7:57 pm
by Henry K. Lee
Steve,
Help a guy do this some years back, very tight. I do not remember what year his was. As I remember, we had to migrate it down to a certain point to roll it out.
Hope this Helps,
Posted: Fri Apr 03, 2020 8:03 pm
Loosen the bolts, lube it with WD 40 so it will slide easier, slide it down enough so it will roll off.
Posted: Fri Apr 03, 2020 10:13 pm
Appreciate the guidance, fellas ! I'm attempting to install an accessory spare wire wheel (Buffalo) mount that attaches to & with the original u-bolts BUT they're too short !!!
I have some 9 leave u-bolts that will do the trick but was trying to figure out the scenario - factory rear spare carrier arms needs to be removed in order to "slide" the u-bolt down towards each corner - man, is tight in there !
I lubed them up John and can manipulate them around.
Posted: Fri Apr 03, 2020 10:47 pm
by DHort
Under my touring it was a piece of cake. I am surprised a closed car is that hard. Now I need to do it under my speedster and I might need to disconnect the body. Wish you luck.
