What's wrong with this photo?
Posted: Wed Apr 08, 2020 10:02 am
by FATMAN
Why do some people do things without asking questions? can you see the problem? Bob
Re: What's wrong with this photo?
Posted: Wed Apr 08, 2020 10:14 am
by Quickm007
LMAO
Fire Wall Brackets suppose to be under the moddling...
Posted: Wed Apr 08, 2020 10:15 am
Kind of makes you want to slap your forehead, doesn't it?
Posted: Wed Apr 08, 2020 10:31 am
by Henry K. Lee
Too much Irish coffee?
Just Sayin’
Posted: Wed Apr 08, 2020 10:41 am
There are lots of people in this hobby that do things like that!
Posted: Wed Apr 08, 2020 10:44 am
by Rich Eagle
Just trying to get your attention perhaps.
Posted: Wed Apr 08, 2020 11:14 am
Working with limited information based resources. Not everyone is on the computer or member of clubs and may have been working with pile of parts. There could have been some logic at time why they did it that way that we are not privy too. Not everyone has been around these old cars as long as some and may have never seen one of this vintage.
Posted: Wed Apr 08, 2020 11:49 am
by mgarrett
I thought surely someone would say...it has a water pump!
Posted: Wed Apr 08, 2020 12:11 pm
by Sarikatime
If that firewall bracket is on the wrong side of the firewall, how did he get the hood to fit right. The hoodformer should be much further from center since the hood is wider than the frame on each side and the firewall bracket should be In front of the firewall and be farther from the frame. I have been fighting with the hood for a week, even though everything is installed properly, after installing a new to me body, nothing wants to line up no matter how I shift or shim. The fun of (lol) playing with your model T while we have extra time due to too much Corona.
Wash your hands for your own sake. Frank
Posted: Wed Apr 08, 2020 12:32 pm
The brackets are on the correct side of the firewall, they just are turned around or swapped side for side. They would have been under the lip of the hood support and you would not have been able to see most of them, only the base mounted to the frame from the angle the photo was taken. The hood up to 1916 would travel in a straight line from the radiator back and would be the same width as the radiator at the rear. The rear would be the same as the front and would sit approx parallel to the inside edge of the frame.
Posted: Wed Apr 08, 2020 12:43 pm
by AndreFordT
those brackets are changed left to the right and right to the left. The distance for the hood rest as it should be.
Just my opinion
Andre
Belgium
Posted: Wed Apr 08, 2020 12:56 pm
by FATMAN
Yes he also drilled out the holes in the early hood former and firewall, Bob
Posted: Wed Apr 08, 2020 7:45 pm
No-one even mentioned that the steering column is not on the right side!!!!!
Posted: Thu Apr 09, 2020 2:32 am
by AndreFordT
Allan than it is on the wrong side
Andre
Belgium
