In car Mag recharge
Farmer J
Last Name: Kramer
In car Mag recharge
Post by Farmer J » Thu Apr 09, 2020 11:19 am
I have a charger whose output is 36 volts and 30 amps. Is this strong enough to charge the magnets in the car or do I need to use 3 12v car batteries
Chris Barker
First Name: Chris
Last Name: Barker
Re: In car Mag recharge
Post by Chris Barker » Thu Apr 09, 2020 12:01 pm
I doubt that 30A is enough. When I have done this job (successfully) with 3 x 12v batteries there was a big spark when I connected.
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Thu Apr 09, 2020 12:08 pm
you can use a dc welder do a search there is a thread on how to do it works great
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Thu Apr 09, 2020 1:57 pm
Farmer Jerry, Search Google MTFCA Tom Carnegie for a very simple detailed method for charging the magnets in the car. Tom is one of the smartest/experienced guys and has researched his method extensively. Multiple Montana 500 winner proves his method as well.
Philip's advice is spot on!
1912 Torpedo Roadster
KeithG
First Name: Keith
Last Name: Gumbinger
MTFCA Number: 4661
MTFCI Number: 6866
Post by KeithG » Thu Apr 09, 2020 3:50 pm
We just charged one yesterday afternoon on a friends '26 Touring and it was easy and the results really great! We used 36 volts from a golf cart battery. Just a quick zap or two does it.
Keith
'14 Touring, '26 Roadster Pickup, '27 Fordor, '25 TT C Cab with Express Bed.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu Apr 09, 2020 4:43 pm
Someone in the neighborhood may have a 36 or 48 volt golf cart. The 36 volt cart,just put your jumper cables to the 2 post that the charger wires go to and you have 36 volt. If the cart is 48, then just follow your wiring and use 3 of the batterys that should be wired in seris "spelling".
Some chargers that put out 36 for a cart,won't put out until there is a voltage from the cart it's self to activate a internal solenoid.
SurfCityGene
First Name: Gene
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Thu Apr 09, 2020 7:46 pm
Sorry if my post was not clear about where to find Tom's procedure.
Here is a link to that thread: http://www.mtfca.com/discus/messages/506218/528397.html.
I believe some search engines find different advertisements than others. Hate that
If you've been looking for a compass and wondering where to place the thing and then trying to figure out where N - S or E - W is and which way your car is pointed Read Tom's post!
John iaccino
Last Name: Iaccino
MTFCA Number: 17802
Post by John iaccino » Thu Apr 09, 2020 8:34 pm
The procedure is also explained in the Dykes Manual.
