More "modern" steering column
Topic author - Posts: 50
- First Name: Matt
- Last Name: Atchinson
Hey guys. So I've started assembling a 27 roadster gowjob/speedster. The T motor is just about squared away. I'm looking at setting up steering soon. Pop has a couple T columns, but also some A columns. I'm playing with the idea of a 30s Ford steering column to give a less sensitive steering for speedster speeds. Can one use an A column? I believe I heard once as well that a later 30s Ford column also fits in nicely.
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
- Last Name: Mazza
Re: More "modern" steering column
One more good detail
- Attachments
- D9DE3C7A-3C91-4F91-B5DC-EB4243A63669.jpeg (71.54 KiB) Viewed 3641 times
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
- MTFCA Number: 26904
You can search for mine I started building, or look on the HAMB forum Model T Gow Job. I too am running an A box...the better '30-31 box. Link: https://www.jalopyjournal.com/forum/thr ... b.1122709/
Interesting that the above pictures, that the end of the A box has been trimmed and turned down to fit in the clamping bracket, yet for some odd reason they still are running wedges on the clamping bracket. Really no need to do both.
- MTFCA Number: 52564
David that is a nice clean job on installing. Chad, what do you mean by wedges?
1920 Dodge touring
1920 Dodge touring
- First Name: Matt
Good looking setup. It looks like I'd have to run the roadster with no sides of the hood though. Hmm, hadn't thought about that.
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
- MTFCA Number: 12542
A lot of the GO JOBS used early Chevy boxes
- First Name: Chad
Edit: Knew I should have kept my mouth shut.....Later Y'all
Last edited by Chad_Marcheese on Wed Apr 15, 2020 8:31 pm, edited 3 times in total.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
That lower strap steel bar is used to dissipate the pressure from the u-bolts equally so not to cause shear.
Hope this Helps,
Hank
Hope this Helps,
Hank
