Texas Hill Country-magneto/flywheel gap gauge
Topic author - Posts: 134
- First Name: Rob
- Last Name: Trippet
- * REQUIRED* Type and Year of Model Ts owned: 18 Ames bodied Cloverleaf, 27 Roadster PU (in progress)
- MTFCA Number: 19169
Anyone in the Hill Country (I’m in Comfort-40 miles W of SA on IH10, and I’ll drive a couple hours!) have a KR Wilson magneto and flywheel gap gauge I can borrow for a couple days? I’ll come to you, and deliver it back in a day or two! Just finished recharging magnets, measuring spools and making sure magnets are N-S around the ring and I’d like to make things easier on myself as I start the “tranny on-tranny off” gap measuring process. I’ve been faithfully home quarantining with just the wife and dog, I’ll socially distance correctly and even pick it up outside your shop and leave it there and I’ll I’ll even throw in a Whataburger gift card for the privilege!
If anyone has an equally easy way to determine magnet plate height around the flywheel with a different method, I’ll try that too!
- First Name: Kirk
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
- MTFCA Number: 345
- MTFCI Number: 141
Re: Texas Hill Country-magneto/flywheel gap gauge
Try contacting Julius or Marvin in Kerrville.
Kirk Peterson
Santa Fe NM
Santa Fe NM
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
When you do, set the ring on (unbolted with no shimms) the. Set the flywheel on when the magnets already set and let the magnetism draw them together. Measure the gap between the ring and block. Should make for an easier time setting proper gap without having to lug the flywheel on and off too many times.
My 2¢
Brad
My 2¢
Brad
- Last Name: Bartsch
- MTFCA Number: 30615
Mike Bender has a good video demonstrating this technique. jb
- First Name: Dale
- Last Name: McMurry
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
- MTFCA Number: 2213
- MTFCI Number: 5309
I have one to loan with instructions if you pay postage both ways.
Dale McMurry Midland, TX 432 559 4130
- Last Name: House
- MTFCA Number: 115
Rob, you can use a dial indicator too. I’ve made a ‘transmission lift’ tool you can use. It’s essentially 3 chain lengths connected with a ring on the lift end and hooks for the flywheel end. When the engine is vertical-nose down- it makes it easier to lift the tranny numerous times
- First Name: Rob
Thanks Sonny! I’ve got the lifting harness, I made what you’re describing when I added a starter to my ‘18 last year. And howdy to you and S, we'll get together for BBQ when this social distancing mess is thru!
- First Name: Rob
Yup, been looking at Mike's videos. Wish I had all his equipment to balance and set up a tranny like he’s able to do. Just have to trust that Henry’s design and construction still perform like they should!
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
- MTFCA Number: 50510
Rob,
I just completed that job yesterday without the KW tool. (I am sheltering at home also). I suggest you look at my thread if you don’t find a tool to use.
Click this link:
viewtopic.php?f=2&t=11807
TH
Click this link:
TH
- First Name: Rob
LOL, great write up, and I HAD researched and read it when I sent out my plea for the tool (which in the end you recommend to use ). But I was close to doing a lot of things I have read about here. My favorite part is the tool was only a 60 mile round trip for you to get, heck, it’s a 40 mile round trip for me to get serious groceries or a hardware box store! I’d make that trip, but all is good, one is coming in the mail! Thanks to all!
