Finding a fan belt issues
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Wed Apr 15, 2020 9:45 pm
Im installing the radiator on the speedster project. It seems with my fan and other things a 27 inch belt is almost too shrot and a 28 inch fan belt is almost too long. The 27 inch will allow the fan to turn but the blades only clear the lower hose by about 1/8 inch. The 28 inch belt allows plenty of room for the fan but the belt just barely rubs on the Bosch front plate distributor housing. I really need a 27-1/2 inch belt (or close)
I have a "clipper belt lacing tool" and could cut and splice a belt using the "clipper" metal splices but Im unsure how well they would work on a automobile fan belt. I use them on my flat belt machine tools and hit miss engines ect, but have never used one a car.
Any ideas on where to find a 27-1/2 inch belt. The micro V belts would also work for me. Thanks
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
MTFCA Number: 25039
Re: Finding a fan belt issues
Post by Divcoone » Wed Apr 15, 2020 10:16 pm
I solved a Speedster belt problem by using the long fan mount bracket. I reduced the fan pulley diameter to clear the timing rod.
Post by Scott_Conger » Wed Apr 15, 2020 10:25 pm
NH Full Flow Float Valves
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Apr 16, 2020 12:53 am
Russ Furstnow can make you a really nice sewn leather fan belt of the length you need,
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Thu Apr 16, 2020 3:48 am
You can get really close with a Dayco belt nowadays Don!!
Dad's name was Don so it stuck.
I cut an inch out of a belt from the parts store. Stitched it back together with stainless wire, for an old lathe... Slow.
Find your perfect belt as you can sir. :)
I have a couple of Off Topic belts I need and Russ was the name I needed to see. Thanks Dan.
Donnie, can't wait to see more... :)
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Thu Apr 16, 2020 8:35 am
I tried using the "size" search feature of the belt manufacturers. All I'm finding in the 27-1/2 inch range is narrow belts. They are only about 3/4 to 15/16 inch wide. Ill contact Russ and see what he can do. I also had our local parts stores look for me. They also only found narrow belts in the length I need. Thanks for the info.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Thu Apr 16, 2020 11:23 am
I seem to recall a spring loaded, pulley type, fan belt tensioner used to be available for the Model T. If they are still and you can find one, that might be the solution. Jim Patrick
