Tbay problem
Topic author - Posts: 197
- First Name: Jim
- Last Name: Eubanks
- MTFCA Number: 49847
- MTFCI Number: 8340
Tbay problem
Anyone else have a problem with tbay today going from one page to the next page of Model T items. I get to the bottom of the page, 50 items and there are no pages to go to next.
- MTFCA Number: 52564
Re: Tbay problem
I just checked mine and yes. In the box to the right of the search box, what does it say. Mine defaulted to all categories but when I changed to Ebay Motors, showed more pages. There have been glitches going on with the system. No one is home at eBay central, everyone is working re-motley, the bots have gone mad.
1920 Dodge touring
1920 Dodge touring
Re: Tbay problem
Try this and if it works replace and bookmark yours. I have it set for 200 per page, if you want a lower count correct that before saving;
https://www.ebay.com/sch/i.html?_from=R ... 73&_sop=12
1920 Dodge touring
1920 Dodge touring
Re: Tbay problem
eBay has lots of problems in listing items of a search. Sometimes you may see the same item more than once when scrolling through several pages. And yes I have had the same issue in the past, where more pages show to list but then there were none (as you described). eBay as many add-ons to your search like "sponsored items". These will pop of if they match the search text but not necessarily specifics (like you see Canada items when you have selected USA Only). Not sure but I think the problem you described happens when you select a sort like Price low to high.
- First Name: Jim
Re: Tbay problem
I found a work around. Just change the number of items on the page once and switch back to your original setting.
- Last Name: Knapp
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster (project)
Re: Tbay problem
On my search there are 4900+ results listed, and only 100 on one page show. There is no button at the bottom to change the number of listings showing per page. There is nothing showing any additional pages to go to. I have not been able to find any "work around".
Re: Tbay problem
Ok try this;
https://www.ebay.com/sch/eBay-Motors/60 ... ion=4%7C10
You will still get a few rat rod and other items, but over all seems to work. I have been having the same issue. Up until maybe Saturday my saved one worked fine.
1920 Dodge touring
1920 Dodge touring
- First Name: Ronald
- Last Name: Dupree
- MTFCA Number: 22940
- MTFCI Number: 15830
Re: Tbay problem
Another example of Ebay breaking something that didn't need to be fixed. I am having the same problems with EBAY motors related searches. This is one work around from the EBAY discussion board.
https://community.ebay.com/t5/Technical ... lse#M69931
It appears that you may have to apply the "fix" for every new search.
Ron Dupree
Re: Tbay problem
I don't think they broke it I think it broke. Might be higher then normal usage with everyone home overloaded something.
1920 Dodge touring
1920 Dodge touring
- Last Name: Dupree
Re: Tbay problem
I don't think so. The problem appears to be strictly associated with EBAY motors searches. Regular EBAY searches are working like they always have been. The 'work around' search appears to be working well too.
Ron Dupree
