27 fordor spare tire carrier question
Topic author - Posts: 162
- First Name: Steven
- Last Name: White
- MTFCA Number: 73
On my 27 fordor the spare tire carrier wheel mounting plate is bent in slightly at the bottom I am thinking it should be flat.
- MTFCA Number: 4838
- MTFCI Number: 115
Re: 27 fordor spare tire carrier question
On that gooseneck rim carrier, the triangular plate should be flat.
But the plate is welded to the tube at a slight angle so the mounted tire on the rim won't hit the body.
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
Steven here are some pictures of my 26 fordor rear carrier with and with out the spare, hope it helps. If you need any more pictures I can post them for you.
- Last Name: White
- MTFCA Number: 73
Thank you both i should have mentioned it is a wire wheel spare tire carrier, and that answers my question.
- Last Name: Codman
My '27 touring car spare tire carrier appears identical to the Fordor carriers in the various photos, and mine came with wood wheels.
- MTFCA Number: 14972
- MTFCI Number: 15411
Most likely scenario was that the carrier originally sported the split rim "Y" and was backed into something - with the leverage of the attached "Y", I would assume it would/could have bent the flat plate.
- Last Name: White
- MTFCA Number: 73
Sounds exactly right.
