Pistons
Pierre-Yves Smits
First Name: Pierre-Yves
Last Name: Smits
Pistons
Post by Pierre-Yves Smits » Mon Apr 27, 2020 5:32 am
Hello guys,
I will soon have to replace my connecting rods because i'm out of shims. Doing so, should i replace my cast iron pistons with aluminum ones?
I know the question was debated again and again, but i'm reluctant to aluminum considering all the problems of piston slap, seizing and so. Iron pistons have a bottom oil ring making piston slap almost impossible, but are heavier. On my car they are quite a lot oversize. If i go to aluminum, should i rebore my block?
Any opinions are welcome.
Pierre-Yves
Belgium
AndreFordT
First Name: Andre
Last Name: Valkenaers
MTFCA Number: 23792
MTFCI Number: 19330
Re: Pistons
Post by AndreFordT » Mon Apr 27, 2020 6:41 am
Bonjour Pierre Ives,
I like the cast iron pistons.
If it was mine and the cilinders are not bad, I should go just for a set new rings and keep the iron pistons.
Just my opinion.
Andre
Belgium
Last Name: Humble
Board Member Since: 2006
Re: Pistons
Post by Humblej » Mon Apr 27, 2020 6:46 am
I agree with Andre.
Pierre-Yves Smits
Last Name: Smits
Re: Pistons
Post by Pierre-Yves Smits » Mon Apr 27, 2020 12:44 pm
Ok thanks,
Merci André, i will stick to cast iron, but replacing the rings might be difficult, because it seems i have a set of aftermarket pistons as my piston rings are very different to stock ford rings.
Philip
First Name: Philip
Last Name: Thompson
Re: Pistons
Post by Philip » Mon Apr 27, 2020 12:50 pm
if the bore is standard used pistons are not hard to find. philip
AndreFordT
First Name: Andre
MTFCA Number: 23792
MTFCI Number: 19330
Re: Pistons
Post by AndreFordT » Mon Apr 27, 2020 2:22 pm
Pierre-Yves,
I send you a PM this afternoon with my email.
Andre
Belgium
