How It's Made-Wood spoke wheels
Posted: Mon Apr 27, 2020 12:11 pm
by Herb Iffrig
This is one I haven't seen before:
https://www.youtube.com/watch?v=xeb5RK-82to
Re: How It's Made-Wood spoke wheels
Posted: Mon Apr 27, 2020 1:24 pm
by FATMAN
I like it, thanks for posting, Bob
Posted: Mon Apr 27, 2020 3:37 pm
by HornsRus
those wheels would not be on my car.they use the bolts to support the car seen at 2:14.you must bore the center of the wheel the same size as the hub.junk. charley
Posted: Mon Apr 27, 2020 5:33 pm
by YellowTRacer
Charlie's correct, The hub needs to really fit tight on the spokes. The person that uses those wheels will hear clicking sounds as he drives, after a few years.
Ed aka #4
Posted: Mon Apr 27, 2020 6:02 pm
I do not believe that enough information is given on the video to come to a conclusion one way or another. We don't know the hole size when the hub went in; don't know the clearance of the bolt holes; and do not know how much "squeeze" the rim places on the fellos and thus the hub.
Thanks for posting the video. Whether or not you agree with the technique, I found it interesting.
Posted: Mon Apr 27, 2020 6:21 pm
by HornsRus
you can clearly see the end of the spokes are square and the hub falls in, you should have to press it in,bolt holes look louse to me.charley
Posted: Mon Apr 27, 2020 6:37 pm
by rondupree
Looking at the credits, this was filmed at Coker's wheel shop
Posted: Mon Apr 27, 2020 6:50 pm
Charlie
I agree, you should have to press it in. In a finished wheel. Those spokes have not been compressed at all yet. I am betting that once the rim is shrunk on, it would be very difficult to press the hub out... Just my guess. If it falls out after assembly, yeah, that'd be a problem. However, I am pretty sure these guys do not have wheels flying off of cars as a matter of course.
Posted: Mon Apr 27, 2020 7:47 pm
by HornsRus
scott, you can put a round peg in a square hole but it wont stay tight very long!!!!!!!!!!!!! charley
Posted: Wed Apr 29, 2020 3:47 am
The pemise that wood wheel spokes are turned in a lathe is put to rest. That might work with later T spokes which are round, but not with oval or teardrop shaped spokes. I think a step was missed in the video. The hole in the centre looks undersized as the spokes are assembled in the wooden felloe. To be able to fit the hub, I think the hole was bored out to suit.
I could be wrong again.
Posted: Wed Apr 29, 2020 7:14 am
by HornsRus
allan look again you can clearly see the spokes still square on the ends and the hub falls in.there was a wheel shop in calf that them that way we put them in a big lathe bored them out the made a spacer to fill the gap. charley
Posted: Wed Apr 29, 2020 10:13 am
by Adam
I didn’t watch the video, but for what it’s worth; I have prints out of the Benson Ford for several wheels and the hub outside diameter to hole inside diameter is between a few thousandths slip fit to a few thousandths press fit. What was important was the precise relationship between the wedge and tennon end of each spoke.
Posted: Wed Apr 29, 2020 10:39 am
by HornsRus
you can make all the spokes from one piece of wood but if the center hole is not tight the car is being carried buy the bolts!!!!!!!!!!!!!!!!!!!! charley
Posted: Thu Apr 30, 2020 10:30 am
by John Codman
Whether you feel that the spokes were not done correctly or not, it was an interesting video. I watch How It's Made regularly, and have not seen that clip before. BTW: Recording that video and posting it online without written permission is almost certainly a copyright violation.
Posted: Thu Apr 30, 2020 11:54 am
John
while well meaning, your concern is unwarranted for this particular video. It is posted by the company which produces these shows.
It is a valid point, though, in that many videos are reposts of other original work and is a useful cautionary statement. That does not appear to be the case here, though.
Posted: Thu Apr 30, 2020 12:39 pm
by Adam
That’s absolutely correct! That is why the bolt holes are between the spokes and every pair of spokes has a bolt between them. Also, the correct bolts have full size shanks and are a very good fit In the holes. All that, combined with the fact the spokes are clamped between two steel plates would make a wheel that is nice and tight EVEN IF the hub was a bit of a slip fit. Such a wheel would perform adequately until such point it was “old and worn out”. Would a wheel with a “light press fit” hub last longer than a wheel with a “slip fit” hub? The answer might range from maybe to probably. Yes, I would prefer a light press fit in my wheel, but the Ford prints tell a story that a slip fit was also acceptable to them so it’s possible a slip fit could have good longevity too.
Posted: Thu Apr 30, 2020 1:00 pm
by HornsRus
tha fit on the wheel in the film looks to be about 1/8 th. as i rember the wheels that came from calf after we boared them we had to make 3/8 s ring to press on the hub charley
Posted: Thu Apr 30, 2020 4:08 pm
My favorite wheel shop is Calimers in Pennsylvania. Their work is amazing. I wouldn't go anywhere else, plus they are accommodating. Their wait list is usually about six months. Some time ago I needed a late 30 X 31/2 steel felloe wheel respoked, and they worked my wheel in with another customers!
That is what I call service.
Posted: Thu Apr 30, 2020 5:17 pm
by John Codman
Scott - Glad to hear that. If the video was posted by the owner of the work, there's no problem. Thanks for the clarification.
