speedster dashes
Topic author - Posts: 25
- First Name: scott
- Last Name: hills
- * REQUIRED* Type and Year of Model Ts owned: 1924 Paco speedster 27 touring
- Board Member Since: 2012
speedster dashes
we have seen your wheels how about your dashboard
- Attachments
- paco dash.jpg (26.8 KiB) Viewed 5629 times
- paco dash 2.jpg (28.89 KiB) Viewed 5629 times
- paco dash 3.jpg (25.02 KiB) Viewed 5629 times
- MTFCA Number: 1219
- First Name: David
- Last Name: Carnahan
- * REQUIRED* Type and Year of Model Ts owned: 1917 Speedster
- MTFCA Number: 49550
Re: speedster dashes
Here's mine....genuine Tennessee Black Walnut
...some people are like Slinkies....they're generally useless but fun to watch when you push them down the stairs.
- Last Name: Kelly
My dash is bare bones.
- First Name: Kevin
- Last Name: Pharis
Here’s a shot of my blasphemous dash with its modern gauges (they do work good tho). I made the dash control panel to look like the ‘ol Delco units of the day, and the starter push button to match. All accept modern switches from the back side. Original Dixie mag switch serves as the main switch for he whole system
- First Name: scott
- Last Name: hills
I need to learn how to take better pictures your guys do way better hey (tomatoe) probably ben awhile since you've heard that surname but that was Kipplings go to for you get that speedster on a run won't call it a RAJO racer till I have a chance to pass you
- First Name: Peter
- Last Name: Kable
- MTFCA Number: 4
Here is the dash on my Speedster
Originally built by Speedster Hall of Fame inductee Vic Jacobs.
Still planning and parts gathering. The dash is a 1926 Dodge, I liked the layout of the dash but more important is the top curve which I'm after for the body. Intending to add a SW water temp gauge in the open hole. Just got the switch and had to find a spacer (copper will nickle plate it later) to fill the gap. Will be using a REO face-plate when done.
- Attachments
- IMG_1067.JPG (62.72 KiB) Viewed 5191 times
Frank
that is a great dash for a speedster
NH Full Flow Float Valves
- MTFCA Number: 14972
- MTFCI Number: 15411
I sure miss "O Great Bald One" - Kipling !
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
I appreciate this thread.
1 thing I do know is going on the dash of my speedster, and that is some turn signal indicator bulbs BIG ENOUGH that I can see them!
The little tiny light in my turn signal switch on the T pickup is so tiny,and I don't see them under the steering wheel. If they were on the dash and big and bright, I would not ride around like a really old man,with my blinkers on!
I want a temp gauge and a clock and of all things a DRINK holder!
Yes I want a drink holder in my T speedster. I like to have a Dew with me and there is NO where on my pickup YET to put 1.
I am thinking maby finding a real old coffee can that is rusted and using it's outer shell and something accross the bottom. Or a Kings surup can.
- First Name: Thomas
- Last Name: Butterworth
- * REQUIRED* Type and Year of Model Ts owned: 1911 speedster
- First Name: Peter
- Last Name: McIntyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Many variations GOOGLE gimbled drink holder Its a Nautical Item
I think a Campbell's Tomato soup can would be just about right!
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
I’m guessing my dash has had a couple different layouts. I’ll be putting an overlay on when I get to it.
Andy
Andy
- First Name: Harold
- Last Name: Schwendeman
- MTFCA Number: 0
Frank - I think "auto-correct" played a trick on you as your post reads "gambled" when you meant "gimbled". In fact, the same think just happened to me from "auto-correct",.....changed my "gimbled" to "gambled",....in fact, it just did it again! I hate "auto-correct" as I have to remember to proofread to correct my "auto-correct" changes that I didn't want!
I corrected it and then just did a submit and it kept gimbled - didn't happen this time2nighthawks wrote: ↑Thu May 07, 2020 3:27 pmFrank - I think "auto-correct" played a trick on you as your post reads "gambled" when you meant "gimbled". In fact, the same think just happened to me from "auto-correct",.....changed my "gimbled" to "gambled",....in fact, it just did it again! I hate "auto-correct" as I have to remember to proofread to correct my "auto-correct" changes that I didn't want!
